what code comes up?
got a problem with my computer. when i start the car, engine light stays on, and the thermo fan comes on straight away. car is running rather slow and ive been told im in limp home mode. any idea how i can fix this? ive tried a couple of memcals but no luck
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
what code comes up?
like i told you on msn its the computer.... hehehehe
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
Try a different ECU.
and 3 Dangerous non ABS VN's
is it possibly that somewhere in the car's diagnosic line there's a fault that makes it think the wires for limp home are connected?
......damn loose connector
Stocky,
Is that good or Bad?
Good that you found it![]()
Bad that it happened, might happen again. What caused it?
Ivan in Oz,
Over the Hill, SEQld
MOTOGuzzi T4 and Cali III Dresser![]()
1985 735i Bemmer............![]()
1998 Statey......
its a good thing. means i dont need a new computer. one of the two plugs on the bottom of the ecu mustve had a loose wire, or having trouble connecting. took the ecu out, checked the wires, plugged it back in, reset everything and my problems were gone
im still getting the engine light popping on and off sometimes when driving, so ill give it an error code check tomorrow
