Results 1 to 24 of 24
Thread: Knocking VN Calais
    Oct 2006
    Default Knocking VN Calais
    Hey guys,
    I hope you can help me, I've got a 1990 VN Calais series 1 motor...
    Steering wheel has been vibrating for a while but i wrote that off as a wheel alignment, its leaking power steering fluid out the bottom somewhere, its burning on the extractors... But the main issue is, its had a loud knocking sound since saturday night just gone, sounds like a bearing or a tensioner pulley but i got no idea, its pretty loud u can hear it no matter where u stand around the car..
    Has anyone had similiar symptoms? know what it is?
    any help will be appreciated!
    Chloe
    5 speed v6 vn commodore
    Dec 2006
    waroona WA
    Oct 2006
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by MzVNCalais View Post
    Hey guys,
    Chloe
    The vibration can be 2 things - 1 wheel balance or related issue and the second is disk roto. The rotor is when you brake and the wheel vibrates.
    The knock - does it happen on startup - all the time or when you change the revs?
    and 3 Dangerous non ABS VN's
    Oct 2006
    yeah i was thinkin i warped a disc, i got vt brakes i dunno, i just gave that info to make sure it couldnt all be related...
    the knock is on start up, i cant hear it when it rev's but it might still be there, its at idle tho u can hear it, it goes quiet, then it goes loud, it seems inconsistant
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    is the knocking only when moving driving????
    could be a loose rocker if it does it on idle or something valve train related
    the power steering fluid, dont know how it could possibly be leaking on the headers, maybe oil from the rocker cover???
    now about your vibrations, this might sound silly but check your wheel nuts mate, you wouldnt believe how many times it happened to me...
    Oct 2006
    hahaha yeah i'll check the nuts, didnt even think of it, and its happened to me before, thought i did my tailshaft, checked the nuts and it was all fixed...
    I cant tell if the knocking is when im driving, cos get the car goin more then 1grand i cant hear anything else lol i know its at idle, it could be there more than that but i cant physically hear it cos the cars too loud
    Dec 2006
    waroona WA
    Oct 2006
    Dec 2006
    waroona WA
    Dec 2006
    waroona WA
    get a stethiscope or a screwdriver and pace it to ur ear and put the other end on the altinator around the water pump or anywhere else the noise could be coming from it should amplify the sound then u know where it could be coming from better
    MY CAR
    Oct 2006
    that works?
    i'll give that ago, i wouldnt think its the water pump, but im stumped on this one, i've diagnosed everything else in a heart beat, but this one has well and truely F***ed me!
    Dec 2006
    waroona WA
    water pumps can get noisy but probably not just check anything that it could possibly be and let us know how u go
    MY CAR
    Oct 2006
  15. #15
    Oct 2006
    water pump sounds fine, i could hear the water running thru, alternator seems fine, power steering pump sounds fine, tensioner pulley sounds off...
    but the noise is so inconsistant, it went away for about a minute than came back for about 3 knocks then pissed off, and then came back, quieter and then louder and then not, there's no consistancy at all
  16. #16
    88GreenVN's Avatar
    Jun 2006
    No oil pressure light? how old is the oil? blocked oil filter? some random thoughts...
  17. #17
    Oct 2006
    cars serviced every 5000ks by myself, i know its not the oil, oil pressure guage is fine..
    i'd say it was the tensioner pulley but its so random,there's no rhythm or pattern to the knock im starting to think something stuck in it somewhere and banging, nothing wrong with it lol but i cant see anything, i'll replace the tensioner pulley anyways, and see how i go, i work at repco i get them cheap as chips lol
  18. #18
    Dec 2006
    waroona WA
    yer wel hope it works i got heaps of noises from my vn now i just dont worry bout them nemore lol
    MY CAR
  19. #19
    Oct 2006
    LOL well i like my VN, and i dont like it making noises, its definately driveable but my vn has always been and hopefully always will be mechanically a1..
    spoke to a few mates today and had a look at it being awake... the tensioner pulley is definately rooted, im gonna go change it now, just wait and see if the knock goes away, but regardless the pulleys gone, so i'll let u guys know how i go...
  20. #20
    Oct 2006
    well i just changed the tensioner pulley, as suspected it was stuffed, however its still knocking, it sounds louder underneath the car, all other pulleys seem fine...
    I am so stumped
  21. #21
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    whoever said something about oil pressure is probably on the mark
    if its inconsistant... i'd say you have oil pressure problems.
    heres a way to find out if its inside the motor.
    drop the oil, catch it to reuse it whatever you want. go buy some really really thick kmart oil, put it in and see if it still makes the noise, let it warm up and check for a noise again. if its gone then its probably a big end bearing. rebuild time
    if its still there and you want to put other oil back in, may aswell do this first, drain a bit of oil, 500ml or so. replace what you drained with diesel and run it for a week or 2, just cleans the motor out, may aswell do it if you already got shitty oil in it...
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  22. #22
    Oct 2006
    I have my suspicions, i'll be spending quite a bit of time on the car over the next few nights, fixing a few things up...
    i'll let ya's know how i go with that.
  23. #23
    Oct 2006
    ok changed the water pump, and did a major service, there's tiny little metal balls in the oil, the knock is still there...
    do you guys think it may be the timing chain?
  24. #24
    vq statsman..5lt
    Dec 2006
    nsw
    metal balls....sounds like bearings are chewd out thats bad i would say
  1. Vk Knocking
    By VK6CYL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2007, 08:08 PM
  2. vr knocking
    By newcomowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2007, 05:50 PM
  3. VR Knocking
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2006, 01:30 PM
  4. frontend knocking????
    By lilkel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 11:39 AM
  5. knocking under car
    By taita in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2005, 05:57 PM
