Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Vn Ss - How Can I Tell If It Is Genuine???
    Dec 2006
    Default Vn Ss - How Can I Tell If It Is Genuine???
    Hi all,
    I am in the market for a VN SS and am wondering if anyone can tell me how I can determine if they are genuine.
    Does anyone know the model codes or similar? I am looking specifically at automatics so if someone has the details relating to auto VN SS's I would be very appreciative.
    Thanks,
    TEMPA
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The Body and Option Identification Plate has the model code on it.
    I dont know all the options but one is the cop ver BT1.
    and 3 Dangerous non ABS VN's
    Dec 2006
    Quote Originally Posted by 88GreenVN View Post
    Thanks mate.
    Got that much myself.
    I need to try to find what the actual model codes are so I can compare them to the one on the build plate.
    Everything I have found so far (using the VIN) points to the car I am looking at being either a 5.0 Executive or an SS.
    I need to narrow it down further....
    TEMPA
    Dan355's Avatar
    Dan355 is online now Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Whats the colour code on the build plate? They only came out in three colours. If you can match these codes with the paint then it should be genuine.
    Dec 2006
    Quote Originally Posted by Dan355 View Post
    Hello mate,
    I haven't seen this actual car yet. Going to see it tonight. It is Atlas Grey.
    Do you know the paint code for that colour?
    Might also be looking at a Phoenix Red one as well so if you, or anyone else, has that paint code too I would appreciate it.
    Thanks for your help,
    TEMPA
    Dan355's Avatar
    May 2006
    I can have a look at mine tonight to get the code for the atlas grey. Might have to do a little research or ask other owners with the other colours.
    VP Executive R-spec
    Jan 2005
    There is a thread all about this on street commodores if you want to go and search for it there
    Dec 2006
    Quote Originally Posted by greenfoam View Post
    Yeah, I just found that via a Google search. Having a read now.
    Thanks heaps.
    TEMPA
    vp ss
    Dec 2006
    colour code isnt going to help you man if its a dolled up exec thats got the matching colour code to the colour like an atlas grey exec or something, look at the susp code if its an ss it will have fe2, that will be a fair indicator, cheers , Mat
    Dan355's Avatar
    May 2006
    Arnt the colours only for the ss models? I have never seen these colours on any executive models. People can get cars resprayed......
    That link would be handy, if someone could post it?
    Thanks
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    even if it was a resprayed exec, the color code would be the same e.g. if a exec was white and resprayed atlas gray the plate would still read that it was white.
    We got rep back, yaaay!
    vp ss
    Dec 2006
    true but he asked how to tell if an ss is genuine, not if the car is the original colour it came from factory with, there were white execs, white ss's phoenix red ss's and phoenix red execs etc etc, there were also other models in atlas grey.
    i think u get the point, to avoid confusion wouldnt it just be easier to look for the fe2 sports susp code that was standard on the ss?????
    that would be easier and athough not definate a more acurate indicator that the car his looking at is an ss or atleast at bare minimum a dolled up bt1!!!!!
    if all fails its simple, just ring holden and give them the numbers and theyll tell you on the spot exactly what the car is and what options it came with!!!!! that works all the time, thats what id do, just to save stuffing around.,
    cheers mat.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Easiest way is the Body and Option Identification Plate. Listed under model it will have VN8VK19-A9F for an auto or VN8VK19-A9G for a manual.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    Dec 2006
    Quote Originally Posted by AirStrike View Post
    AirStrike
    That certainly sounds the most direct way of verifying.
    Thanks for all the input guys.
    TEMPA
  15. #15
    pumba's Avatar
    pumba is offline OMR346
    VZ SSZ
    Jan 2006
    brisbane southside
    yea when i bought my VPSS, i went to a holden dealership and asked them to run the VIN to see if its genuine. they ran it, told me its a VP, a V8, a white sedan, it has FE2, when and where it was built, but they couldnt tell me if it was a exec, or a SS. they said SS's are only glorified exec;s, which is tue. but then it didnt really worry me if it wasnt a genuine coz i got it cheaper then alot of VP V8 executives anyway lol. but i did check into it abit more and found out it is a SS so its all good
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by pumba View Post
    Correct, on the computer system they have the model is listed as an exec. The way I said is the only way to tell.
    AirStrike
  17. #17
    pumba's Avatar
    VZ SSZ
    Jan 2006
    brisbane southside
  18. #18
    vp ss
    Dec 2006
    why is it that when i rang holden with the numbers of my car they told me that it was an ss and gave me a description of every option the car had. if the numbers matched etc etc
  19. #19
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by GMSSVP View Post
    They can guess its an SS based on the option codes, etc but the body is actually listed as an exec.
    AirStrike
  20. #20
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    fair enough. what would it be for a VP SS auto then?
    Almost the same as the VN. Would be something like VP8VK19-A9F.
    AirStrike
  21. #21
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    yer but if u do a microcat lookup with the tag (L000000) it gives you the option codes and if they were used on that car.. so if im looking up a rear bar and i type in the tag and it gives me an ss bar then its genuine ss.. if it gives me an exec bar then its a mockup.. they should have bee able to tell you
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
  22. #22
    Dan355's Avatar
    May 2006
    Only ss's came with the Atlas Grey option hence looking at paint code. ie 2H023
  23. #23
    vn v8 5 speed commodore executive
    Sep 2005
    moree
    so if i found a vn ss atlas grey wat code would i look for to tell me if its a true ss
  24. #24
    Keesh's Avatar
    Jan 2006
    um its in the vin.. im not sure off the top of my head but i can tell you 2moro afternoon after work.. theres like letters in there that say 8VL or 8VK or 8VX. i no that 8VX is calais, ss would be something similar but i cant tell you off the top of my head sorry.. im only an apprentice but it breaks the vin up into sections, giving you where it was assembled, options, v6/v8 trim style etc..
  25. #25
    Keesh's Avatar
    Jan 2006
    but yer anyone can giv me a vin and ill look it up
  1. VT VX Genuine TowBar Kit
    By clubbie_50 in forum Parts And Other Items For Sale
    Last Post: 12-12-2007, 11:29 PM
  2. Anyone used non genuine panels?
    By ascension24 in forum General
    Last Post: 18-10-2007, 09:20 PM
  3. Genuine VR SS?
    By QWK-11E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2006, 11:47 PM
  4. FS: Genuine HDT VK brakes
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 14-06-2006, 11:23 PM
  5. genuine aero ????
    By bitch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2006, 05:06 PM
