Results 1 to 5 of 5
Thread: Replace VN Calais loom with VP Calais loom?
    Jan 2005
    VIC
    Default Replace VN Calais loom with VP Calais loom?
    Hi all,
    I'm planning on rebuilding a car (not a Commodore) that has a 5.0 engine transplanted into it from a VN Calais, which effectively has two looms - one from the 5.0 to the ECU only (Holden loom) and the other for lights, central locking, power windows, etc. (non-Holden loom).
    What I'm thinking of doing is replacing the VN loom with a VP Calais loom, so that I can get the engine immobilser security, remote keyless entry, remote boot release, etc. from a BCM.
    Maybe I could even hook into some of the other nice features in the VP Calais loom such as power windows working for a bit after the engine is turned off ...
    I don't think I can use a VP 3.8 Calais loom, so I will need to get a VP Calais 5.0 loom, is that correct?
    Has anyone done this before? Are the VN and VP looms similar enough so that I could use a VP Calais loom on a VN 5.0 engine?
    Thanks,
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I dont think the VN Calais has a BCM.... thats compatible with the VP
    and 3 Dangerous non ABS VN's
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Jan 2005
    VIC
    Cheers, thanks for that.
    So will the VN Calais 5.0 engine work with a VP 5.0 Calais loom and BCM?
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    if you change the entire vehicle harness, effectively making it a VP
    the binnacle controls are different as well
    theres probably more small differences too
LinkBacks (?)
  1. 09-02-2008, 11:46 PM
  1. Can I replace VN V8 loom with parts of VQ V6 loom?
    By holdenrules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 03:02 AM
  2. VN Calais dash loom
    By 1redVN in forum Electrical Wiring / Questions
    Last Post: 06-04-2007, 11:13 AM
  3. W.T.B. VN Calais Loom
    By VN-SV-89-LE in forum Swap / Wanted to Buy / Trade
    Last Post: 27-09-2006, 06:42 PM
  4. Vr Calais Wiring Loom
    By troy5.7 in forum Electrical Wiring / Questions
    Last Post: 03-04-2006, 01:04 PM
  5. VP Calais Loom Connectors - where to buy?!
    By neddo1981 in forum General Discussion
    Last Post: 19-12-2004, 05:31 AM
