Results 1 to 21 of 21
Thread: convert from power to manual steer?
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    Default convert from power to manual steer?
    hey pplz, just wondering im looking at getting rid of the power steering, and i need to get some sort of pulley or something, just wondering if anyone can help, and im pretty sure i can use a VL rack and steeringshaft
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    pez06's Avatar
    pez06 is offline PhoebeGirl
    1978 VB Commodore SL
    Oct 2006
    Mildura/Ballarat
    lol, waiting for someone to say that, well actually waiting for someone to reply, well the main reason i want to go manual steer is to get rid of all the power steer fluid leaking all the time, well i have fixed the pump for a little while until i can get it to manual steeer
    cheers, nick, just using gf account
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    by memory you can use the vl steering shaft, different.
    what you have to do is get a vn manual steering item that was fitted into some of the vn's over in new zealand.
    Vn
    Nov 2006
    Glen Iris, Vic
    i used to have that problem, u can get something that you put in ur power steering fluid, can't remember what its called an it kind of seals up the inside of the pipe n stops most leaks, if thats all thats the problem maybe you try something like that i'll see if i can find out what the stuff is for you if your interested.
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Yeah i put some stopleak stuff in my power steering. It went from toping it up every week, to topping it up ever few months so im happy with that.
    Australia. Love it or leave it
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    thats just crazy...why get rid of power steering?? your going to have to start working out at the gym just to be able to park your car! lol
    fixing a leak would be easier and cheaper than converting to a different system. if your still leaking power steering fluid after the pump has been re-sealed, look into doing the hoses...especially the hi-pressure one. hoses dont last forever, they get hard and brittle from heat and will loose their ability to seal at joins, even when you've done the hose clamp up tight.
    May 2005
    Mildura
    well am thinking about the VL rack and using the VL inetermediate shaft on the steering column, and it actually wouldnt be that hard to steer as the gear ratios in the steering box are different to power steer, i drove my car for a bout 5 days with now power steer and its not that hard at all, i can do on the spot turns with one hand still, would just be heaps easier and less hassles to be without power steer, and also i think i need an idler of some sort to get the belt going around or something, thanks guys, im actually getting somewhere now
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    it would be like driving a kingswood 6 with bit betta ride more grunt n a shitload smoother lol
    May 2005
    Mildura
    yep vks is about spot on there but i was thinking it would be more like a VB but a lot better and more comfort,
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    you just need a vl manual steer rack....
    direct bolt in...
    then maybe holden have a belt for no power steer? I know they have one for no a/c....
    May 2005
    Mildura
    na they dont make a belt for no power steer i dotn think as the tensioner needs the power steer pulley to keep it tight, and yeah it probably is cheaper to get a new pump, but i still trying to change it to manual steer
    mickVPace's Avatar
    mickVPace is offline Virtually Perfect
    VP BERLINA
    Dec 2009
    Quote Originally Posted by potshots007 View Post
    well am thinking about the vl rack and using the vl inetermediate shaft on the steering column, and it actually wouldnt be that hard to steer as the gear ratios in the steering box are different to power steer, i drove my car for a bout 5 days with now power steer and its not that hard at all, i can do on the spot turns with one hand still, would just be heaps easier and less hassles to be without power steer, and also i think i need an idler of some sort to get the belt going around or something, thanks guys, im actually getting somewhere now
    hahaha on the spot one hand turns ya meat head lol
  15. #15
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by mickVPace View Post
    WTF does that mean? Also, please look at post dates, this thread is three years old.
  16. #16
    mickVPace's Avatar
    VP BERLINA
    Dec 2009
    read what he said he reckons one handed on the spot turning in a commodore with broken power steering.. i doubt it. BUMP
  17. #17
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    cause thats now relevent 3 years later is it.....
    The Black Beauty
  18. #18
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I've driven my Calais without powersteering before (and blown power steing is heavier than manual steering) one handed. Quite easy in fact.
    Think you should take your shovel and opinion to a different thread
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  19. #19
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    manual steer isnt as bad as u guys say it is. hell i had a VH for months and didnt notice the steering. once ur moving its fine and i guess with the terrible track record that the VN's had with powersteering leaks even with new parts it just means it gonna leak again soon.
    I think manual steer isnt a bad option if ur willing do to it, it means no more maintenance and u will get buff while driving haha
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
  20. #20
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Quote Originally Posted by STEALTHY™ View Post
    Lost a belt a few weeks ago and was barely able to turn the car into the driveway and im not exactly a small guy.
    But after hearing how you were able to still turn it easily it makes me think that maybe there is something wrong or a bit dodgy with my steering. It's not leaking anywhere and is full of fluid, any other reasons why it'd be so hard?
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  21. #21
    VT V8 Calais
    Mar 2007
    My pump failed on my VT Calais and it wasn't going anywhere, It was an effort to get it out of the car park.
    50LTRv8
  1. Any one with a manual steer VN?
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2007, 03:02 PM
  2. power steer pump overhaul
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 05:15 AM
  3. Adjusting power steer belt
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 10:06 PM
  4. WANTED: Power steer pump
    By maddog in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 01:18 PM
  5. WTB: VK V8 extractors, suit power steer
    By broderikb in forum Swap / Wanted to Buy / Trade
    Last Post: 01-05-2006, 08:39 AM
