Results 1 to 13 of 13
Thread: Rattling VN V6, very annoying!!
    94 holden belina sedan 5L V8
    Sep 2005
    Auckland, New Zealand
    Default Rattling VN V6, very annoying!!
    Hi all,
    I have a 1990 V6 sedan, and when i accelerate i hear a rattling sound coming from the engine, it will stop when the trans changes gear, or if i take my foot off the accelerator, i think it may be the timing chain but not too sure
    any ideas??
    cheers
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    maybe the belt tensioner, but it is most probly the timing chain. with it idling watch the belt tensioner and see if it is moving around much.
    SiLeNt-SoN's Avatar
    SiLeNt-SoN is offline 2000 WH Statesman
    2000 model WH statesman
    Sep 2006
    Hey
    Yeah mine does the exact same thing, when i excellerate it makes a rattling, scraping sound, and when i take it off it stops..
    If it is timing belt, how can this be fixed??
    WH STATESMAN
    1990-VN
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    I hear this noise on alot of VN to VR Commodores, mine has developed it aswell, so I would like know exactly what to change.
    SiLeNt-SoN's Avatar
    Sep 2006
    Hey,
    I had a look today, i am thinking maybe the cogs that the fan belt runs on is warped a little or not tightend enough! could this be right??
    WH STATESMAN
    1990-VN
    VP
    Oct 2006
    Adelaide, Blackwood
    id say the belt tensioner, simply take it off (its left hand thread btw) and re grease the bearings then put it back on.
    have done the above a few times on my vp.
    VN Lexcen V6
    Oct 2006
    Mildura
    when we put a new timing chain on my vn it still rattled cos the cogs where worn aswell. try replacing the chain, tensioner and cam sprocet, should only cost bout $40-$50
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    JP Performance billet gear set with multi position keyway NZ$179 doesnt include tensioner though it could also be worn balance shaft gears
    Aug 2006
    Just finished installing the above gear set in my mates vn opened it up and the tensioner was gone sheared off and the chain was stretched to the point you could just about touch both sides together with it on. has done at least 150000 kms like that obviously without the tensioner only a holden could do that.
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    worn balance shaft bearings, most likely the rear.Just did them in my son's VN ser 1..
    Tony 308vkcalais:
    Aug 2006
    just put the above set in my mates vn now quite as a mouse maybe due to the fact that the chain tensioner had sheared off 150000 ks ago and the sides of the chain were just about touching together
    Subaru Liberty
    Dec 2003
    I got some pacemaker extractors, some sounds I used to hear are gone, apart from that tiny scraping sound that comes at 2500 to 3000rpm. The belt tensioner and harmonic balancer are fine, I might replace the timing chain as the car has done 220k.
    holden08 is offline never late in a 308 !
    VP SS 5lt 5sp
    Feb 2007
    pull the timing case of and replace chain and tensioner, the dampner more often than not will snap off !!
  1. rattling
    By BLOWNSS in forum Car Audio
    Last Post: 03-05-2007, 05:41 AM
  2. rattling...
    By CRAIGO_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 12:14 AM
  3. Rattling
    By spauldj308 in forum V6 Development And Modification
    Last Post: 04-12-2005, 07:07 AM
  4. rattling vk
    By bigazza in forum Car Audio
    Last Post: 11-11-2005, 12:03 PM
  5. rattling
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 09:02 PM
