Results 1 to 6 of 6
Thread: Faulty ignition coil making engine run rough?
    VY V6 Acclaim Wagon
    Dec 2006
    Default Faulty ignition coil making engine run rough?
    The other day i noticed that my engine was miss firing when i was trying to start it and though it was a tad bit strange but after i drove it for about a minute it went away. Anyway i replaced the leads and spark plugs but then the problem seemed to get even worse. So i took of the coils and checked them all and 2 of them read around 6.67ohms and the other around 8.5ohms, would this cause a missfire and rough engine running? Also how much should i be looking at for a new one? Cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The CAS can be a problem with a missfire on the 3.8L. Some have suggested cold water on the CAS if the car stops (when it gets hot and has started to play up.)
    Dont know about the ohms - but I guess they should be the same....
    and 3 Dangerous non ABS VN's
    VT Berlina & mazda 2 DE
    Jul 2006
    Without knowing for sure I would say high chance that's your miss. Second hand shouldnt be up for much, otherwise I hear they are worth around $200 odd new
    VN Executive S2
    Jul 2006
    When I bought my Series II VN the guys at the yard put a new coil in it cause they said it was running rough.
    Primary resistance should be 0.3-1.5 Ohms.
    Secondary resistance should be 5000-7000 Ohms.
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Yeah check the O2 sensor if the car is runnin rough. But when u say it goes good do u mean the car will run like really bad then its like the computer kicks in and it runs like a baby again. i have the same prob but.
    VGV8Ute is offline Aussie Muscle Car Lover
    Dec 2006
    Generaly if a coil is begining to break down you will notice it gets worse as the motor heats up. Carbon tracking can cause a problem with coils in much the same way as it does with a distributor, check for tracks and clean with contact cleaner. Also check to ensure the dust caps at the ends of the leads are on and sealing correctly.
  1. Question on ignition coil
    By snowman12 in forum Electrical Wiring / Questions
    Last Post: 23-10-2009, 08:40 PM
  2. MSD Ignition Coil
    By ThongyVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 09:33 PM
  3. Fitting VL ignition coil to an MG
    By bezz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2006, 11:42 PM
  4. Test VT Ignition Coil
    By daffyy30 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 07:30 PM
