Results 1 to 20 of 20
Thread: Help! Is my DFI module dying?
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    Default Help! Is my DFI module dying?
    Hello all,
    Today as I went to start my car it turned over but no spark. Mr NRMA came along and got me going (most of the way home) by thinking it was a dodgy connector, gave the plug a wiggle and it lept into life.
    Tonight I removed the coilpack/DFI module in an effort to get to the plug at the base. I noticed that the DFI module (not the coil) sounds like it has sand or something in it when I shake it. I have my doubts this is good.
    Thoughts??
    Mike
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Is it a Vn DFI module of the upgrade VP. I thought myne was a Vn so i brought a new one then found out that its a Vp. I would b guessing it would be the Vn 1 coz it is big compared to the vp. the vp is flat. But the rattling wouldnt be good at all. i would b inclined to get a new one. but dont make the same mistake i did
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    I have replaced my S1 module for a S2 one. I am still keen to replace the plug, but at the moment it seems to be behaving.
    Mike
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    sorry to revive such an old thread but i am having the EXACT same problemo at the moment and sometimes it has caused the engine to cut out while im actually driving............it had me rooted as to what it was and it also sometimes made my car rev up and drop down revs while warming up in the morning but had no problem when it was warm...........
    my mechanic just had a fiddle with the dfi module and it worked sweet for a few days then yesterday it wouldnt even start, i checked the leads and there wasnt even any spark getting to the leads, so i loosened the dif module screw that holds it to the coil pack and it turned right over.
    Would i just be better off buying an all new assembly? and i hear you cant fit VR assemblys to a VN / VP? only the VS ones will fit...........
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    sudden spark cut? like it just dies then wont go on again? 5 mins later start up and drive normal?
    thats ya DFI!!!!!!!! had the same thing happen last week
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    or possibly the CAS but ifthe dfi has something loose in it then that can't be good either
    Body by Holden, Soul by Brock
    the Legend will live forever
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by PaRaDoX616 View Post
    yep thats the one..........if ya try and start it straight away it struggles a bit but turns over..........oh wells new DFI module and coil pack here we come..........hmmm
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by immortality View Post
    well apparently my mechanic said the terminals were getting all loose and buggered so it should really replace it anyway i suppose
    is replacement just a matter of hooking one end of the DFI module into the ECU and the other end into the coil pack and then mounting the coil pack and hooking the leads to the coil pack?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    well coil packs have the big lug on the end and the grounding strap to the chassis and 3x11mm bolts on the bottom.. 5 mins swapo job
    the bolt on the wiring lug is 7mm aswell
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    yeah but the other end just hooks into the ol' delco doesnt it? there are 2 plugs that run into the computer 1 of them is the DFI module isnt it?
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    clean and tighten the terminals in the dfi connector so they have good contact on the pins in the module
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Doctor Bob View Post
    they usually cut out from being broken, but cleaning the terminals is worth a try but i honostly dont think it'll work
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Thats the way Paradox, tell a Holden technician that he's wrong........Rob would have worked on more Holdens than you have had hot dinners!
  15. #15
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    yeah i have done that about 6 times in the space of about 2 months........doesnt really help much........well it doesnt help at all........tightened them and cleaned them using contact cleaner and one of those bottlebrush cleaner thingys (a soft one)..........still doing the same thing..........
  16. #16
    Doctor Bob's Avatar
    May 2004
    if the car runs ok when you move the connector & you have tightened the terminals correctly the connection in the DFI may be faulty....
  17. #17
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    yeah thats what i kinda guessed was happening.........errrrr CRAAAAAAAP!!!! oh wells new DFI module here we come..........anyone know where to purchase one thats NOT ebay?????
  18. #18
    Doctor Bob's Avatar
    May 2004
  19. #19
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
  20. #20
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    its all good wasnt the module itself..........was a couple of wires in the loom end that connects to the coil pack had come out of the terminals on the plug..........plus a few of the pins were pretty buggered.........myself and my mechanic just cut her off clean at the wires and "grafted" a new plug on, soldered the wires and heatshrank the connections.........worked a TREAT!!!!! runs just and smooth as she did before all this came about..........as before you could move the plug at the coil pack a bit and she would cut right out..........and you could do that over and over.........now when you grab it and move it a bit she still runs..........just as she should
  1. Help! My VN is dying
    By down_with_the_system in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 01:24 PM
  2. My Car Is Dying
    By outlaw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2007, 10:03 PM
  3. Dying VR?
    By pineforest in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 11:19 PM
  4. VT unexpectantly dying?
    By SweetWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 12:21 AM
  5. my VS is dying help
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 08:11 PM
