Results 1 to 6 of 6
Thread: crankshaft sensor
    VR Commodore S2
    Jul 2005
    Default crankshaft sensor
    hi guys, VN has been running really rough. backfires on gas, stutters & cuts out on fuel, so i changed spark plugs...no change. changed coil pack cos it seemed to do it more when hot... then it did it again so im tippin its the crankshaft sensor, is there any tricks to changing it or just pulley off change sensor etc??
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Harmonic balance off first n lock tight the bolt back on.
    If you've had a backfire your MAP sensor may be stuffed too.
    and 3 Dangerous non ABS VN's
    VR Commodore S2
    Jul 2005
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    I had the same prob. I first replced the ECU and that made a little change but then i thought well i change the throttle body which made a really big difference with gas. It actually sounded like it was running 6 cylinders not 4. then check the O2 Sensor. But yeah change the CAS. That will make it start better.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    you have to alighn the sensor with the cups on the back of the harmonic balance. if you dont get it in the right spot it will chew out the old sensor in a mater of seconds.
    you will see what im talking about when you pull it apart
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VR Commodore S2
    Jul 2005
    Thanx all for the input, thought i'd let you know all is good. Took a bit to crack the bolt so (being little) i used leg power haha stronger! yeah great look! squatting under bonnet. anyway test code 12-- no faults.
    GO ME
  1. crankshaft bolt?
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2010, 11:26 PM
  2. Error code 41, Crankshaft Sensor
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:23 PM
  3. Crankshaft Question
    By dezrik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2006, 01:22 PM
  4. Now that's a Crankshaft!
    By IanG in forum The Pub
    Last Post: 06-05-2006, 10:50 PM
  5. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
