I've been told that the injectors out of the 2.6 4 cyl injected magna's of TP and TR vintage are a straight swap for the VN/VP 5L injectors (obviously once you get two sets of the magna injectors).
These injectors are supposed to be higher flowing that standard ones and are supposed to be the same as the HSV ones (same part number).
Can anyone confirm this?
i can confirm that the magnar injectors do flow more but you will need a chip to compinsate for the extra fuel.
they not exactally a straight swap. you need to change the orings over form the std injectors as the magnar o rings are smaller, but other than that they are a simple job on a 5ltr
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
