Results 1 to 7 of 7
Thread: Need Help VN stalls and Smells Funny
    Jan 2007
    Default Need Help VN stalls and Smells Funny
    Yeh i need help i have a vn executive and in the last couple of weeks in has been idling rough. then lately it has stalled a couple of times ESPECIALLY when i make a hard right turn. it also smells funny after i start it just afta it stalls. Has this happened to neone else. I think it might be the fuel pump???? Any Ideas??
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by haynze_125 View Post
    Could be the fuel pump, TPS or a dodgy earth.
    Are the engine mounts OK?
    and 3 Dangerous non ABS VN's
    Jan 2007
    Yeh it smells sorta like burning ruber or fireworks sortof.... i had a look in my engine and decided to flush and change the coolant. The car still idles rough but not as rough as it used to and also it hasnt stalled once since i put the coolant and ive been turning it as hard right as i can. I also topped up the power steering fluid a bit aswell
    88GreenVN's Avatar
    Jun 2006
    The old VN's are running ruff more and more. Other things to look for are the DFI/coils, plugs n leads, fuel regulator and temp sensor. All could be doing there bit to make the car run like shit.
    How is the fuel ecconomy?
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    I had a bad problem like that with it running bad and stalling when i put the gear into another like park neutral. Then i changed the O2 sensor. they are meant to be replaced every 80,000 k,s and now its runnign good. I got myne brand new for 41 but make sure its wiring is corrcet if replcing them. Its ether 1 or 2 wire O2 sensor. good luck
    VP ute
    Mar 2006
    do you have any fluid leaks from the power steering rack?
    It is common for a Commodore to stall when put on full lock quickly or put in gear and have the steering operated at the same time.
    It is possible that you may have some power steering fluid leaking onto the exhaust when it goes full lock but it would be unlikely to be the smell you are smelling. Have you cleaned your car? Have you had a shower?
    Seriously the sort of smell you described is something I would associate with an electrical fault. Something would have to overheat or burn to make a smell like that.
  1. Smells of Petrol
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2006, 01:55 PM
  2. Smells Like ...?
    By HER82 in forum The Pub
    Last Post: 07-11-2006, 09:34 PM
  3. air con smells like petrol
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 06:21 AM
  4. smells like S*#T
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2006, 01:21 PM
  5. My VN oil smells burnt????
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 11:45 PM
