Results 1 to 8 of 8
Thread: Replacing 02 Sensor
    Dec 2006
    Default Replacing 02 Sensor
    Hi Guys,
    Been having some dramas with my 93 VP Calais. Mainly a really rough, unsteady idle. Cleaned the IAC and throttle body, checked all the plugs etc and ran a diagnostic. Got a Code 13. I'm going to replace the O2 Sensor and see if that helps.
    How hard is it to replace? I know a little about cars and my brother knows a fair bit. Is it a simple task to do? I'd rather have a go myself before paying someone else to mess around with it.
    VN Commodore
    Feb 2006
    very very easy. undo the plug and then undo the sensor. the once unscrewed screw in the new one and pulg the wire in.. done..
    VY V6 Acclaim Wagon
    Dec 2006
    I took mine out the otherday to see what condition it was in. As far as i can remember u need a 22-24mm spanner and i managed to get to it from the engine bay, some from under neath. im also getting a new one off ebay for $30 delivered, pretty good price as far as i could see, try this link if u want one http://cgi.ebay.com.au/NEW-UNIVERSAL...QQcmdZViewItem
    Dec 2006
    Thanks for the quick replies. Sounds like something I can do myself this weekend.
    VX II Calais L67
    Dec 2005
    Yeh I did my VP Calais as it was giving the same error code, as said above it's easy as.
    thechubybear's Avatar
    thechubybear is offline thechubybear
    VL sl , Body Kit Project
    Jan 2007
    Central Queensland
    hey guysmy vp series 2 ..stops after about 6 km and loses power any ideas.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by thechubybear View Post
    Fuel pump? CAS?
    and 3 Dangerous non ABS VN's
    Jan 2007
    Central Queensland
    Default hey thanks
    yeah i thought of that but it backfires really badly then loses power...my plugs die quick as well...could it b valve stem seals?
  1. Replacing Sun Sensor?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2007, 10:22 PM
  2. Replacing the o2 Sensor????
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2006, 08:47 PM
  3. replacing Coolant temperature Sensor
    By Matt H in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2006, 09:50 PM
  4. replacing crank angle sensor on vs
    By pumba in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2006, 05:56 PM
  5. Replacing The O2 Sensor
    By Tony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2004, 10:19 PM
