Results 1 to 12 of 12
Thread: differences in vn v6 and v8
    VN v6 s2 Berlina 5spd
    Mar 2006
    Default differences in vn v6 and v8
    im just wondering the differences in vn v6 and v8.
    i know afew things are different. but exactly what?
    I have tryed searching but cant find much.
    will the v6 mounts bolt up where the v8 was or do i need to change the crossmember?
    if so how do i change it and what needs to be changed with it?
    i have a compleate vn v6 manual with no front end
    and a nice vn calais shell but it was a v8.
    i wanted to swap over the v6 into the calais shell but i need to find out what needs changing exactly.
    cheers.
    VP Executive R-spec
    Jan 2005
    Is the calais a shell really or a rolling car complete minus the engine? In the end mostly all you need to do to swap either engine to either car is undo the K-Frame, suspension and motor and stick it in the other shell and all the electronics that goes with it
    VN Commodore
    Feb 2006
    if ya want to sell the calais shell and it has all the electrics let me know.. i would be pretty keen depending on the price..
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    If its a straight body ill take the vn calias as well..... sorry for hijacking
    i just need one...
    aZK.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VP ute
    Mar 2006
    You will need the instrument cluster as well as there are minor instrument workings differences between the V8 and V6
    VN Commodore
    Feb 2006
    at least the v6 clusters are not that expensive on ebay. i got one for $20
    Mar 2006
    thanks heaps for the replys,
    i would sell the shell but i need it as my berlina is stuffed
    But i have a compleate vn calais minus engine and gearbox.
    the "problem" is it was a v8 and im unsure if it will be a easy swap for a v6. This might sound stupid downgrading from a 8 to a 6 but im on my ps
    and i dont think an 8 is a sensible idea for me yet.
    So basically i have a compleate v6 vn 5 speed berlina with no front end and
    i wanted to swap the engine and box and put them in the calais which only needs an engine and gearbox.
    I have swapped my old berlina from a auto s1 to manual s2 so i have a small amount of knowledge and i'm wanting to start this conversion im just unsure how hard it is. And the mounts for the 8 look different.
    Attached Thumbnails Attached Thumbnails differences in vn v6 and v8-me-019.jpg   differences in vn v6 and v8-me-013.jpg   differences in vn v6 and v8-me-014.jpg
    VN Commodore
    Feb 2006
    Mar 2006
    i know you need to change the comp,
    radiator
    tail shaft?
    diff?
    fuel pump?
    front springs/shocks?
    power steering pump
    air con compressor thing
    dash cluster
    k frame?
    but what else.
    does anything need to come out with the k frame?
    how do i remove the k frame?
    cheers 4 the help.
    VP Executive R-spec
    Jan 2005
    The kframe has 4 bolts under it and the rest of the suspension will come out with it if you want, seems a shame to turn a almost perfectly good V8 calais into a V6 though but oh well maybe you can keep all the parts for later
    Mar 2006
    cheers.
    ideally if i was abit older i would probly get a 8 for the calais.
    But cause im on my p's i dont think its wise as its illegal and insurance will be expensive.
    maybe even get an 8 in afew years.
    Mar 2006
    cheers
    where are the bolts located to remove the k frame?
    is it 2 bolts underneath on each side?
    and just the engine mounts?
    does any1 have any pics?
  1. What are the differences VN SS and VP SS?
    By willygrice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 06:26 PM
  2. VX differences
    By zohpm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 10:35 AM
  3. VY SS and VZ SS differences
    By hothouse vy s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2006, 12:33 AM
  4. V8 differences
    By bangers in forum General
    Last Post: 20-06-2006, 02:12 PM
  5. vs/vr differences
    By sarj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2005, 12:32 AM
