Hey people, first problem i got is no air con. when i push the button to switch it on nothing, not even a fluctuation in rpm to show the compressor is on. Any pointers to where to look first would be great. Also my cruise control doesn't seem to work either, i switch it on light comes on drive at 60 press set but nothing, am i doing it wrong? if that is the right way then is there anyway to test the cruise control unit? Cheers
check your fuses first. cruise is something like 11 on the vp's.
does the heater fan still work?? if it does, then id be testing the ac compressor fuse/relays.
when my cruise went, i just had to adjust the brake switch which is found when u flip the panel down under the steering wheel. its found to the left of the fuses on the pedal arm
ok checked the fuses and all seem to be fine, where abouts is the relays/fuses for the AC and whats an easy way to check if there is any gas in the system?
Also how far in should the brake pedal sensor be and what colour wires connected to it?
are you turning the fan on when you turn on the ac?
it will most likley be out of gas
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
