Results 1 to 14 of 14
Thread: VN Power Steering Pump leaking
    VS Equipe Series II
    Jan 2005
    Unhappy VN Power Steering Pump leaking
    Hope someone can help!!
    I've replaced my power steering pump 3 times in the last 3 weeks!. Yep, that's 3 in 3 weeks and another one crapped itself this morning.
    Can anyone help!! I have no idea why they're going. We drive the car once or twice, and they're fine, then they just start pissing out fluid. It's not the hoses, it's the pump itself.
    WE drive a VN commodore, but it's recently had a new motor and gear box installed. (VR series II engine) We've only had the problem since then. Luckily, the first 2 pumps have been replaced free but this one isn't covered. My son has just gone off to buy another one; a reco one, but if this ones dies, I don't know what we'll do.
    Does the VN have a history of this?? Or am I just unlucky
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    All commodores have power steering issues. My VN had 2 leaks and a broken high pressure hose connection (just a few months ago), my VS and our VT. Even my old VL.
    Power steering is a commodores achilles heal... That said... Its better than not having power steering
    But 3 in 3 weeks... I say theres a hidden problem. Either its NOT the pumps or something else is causing the pumps to fault.
    5 speed v6 vn commodore
    Dec 2006
    waroona WA
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like you might have some contamination in the fluid. Did you flush all the fluid out of the rack when you replaced the pump? When I replaced my power steering pump, there was a note in the box to say that the warranty was not valid unless the whole system was flushed with fresh fluid.
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    yer might be a blocage somewhere, maybe youe rack has shit itself and its losing pressure somewhere?? are you buying new ones or organising change overs? or even worse second hand? at work we do reconditioned ones and sometimes thats a shit idea.
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Noooooo don't tell me that! I just put a reco one in mine a couple of months ago! It's going OK so far though And yeah I kinda blew off my high pressure fitting too so had to replace that line. Was a pain. The high pressure fitting was entirely my fault though *cries*
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    sounds like you may have a problem with the rack, does it turn normally like it use too? does the pump whine? you either have contaminated fluid which is damaging the pump or some sort of blockage maybe in the rack which is causing the pump to overpressurise and stuff the pump maybe. maybe try dropping the return line from the rack to the pump(into a container) and see how much fluid you get out when you run the engine (don't let the pump run dry though) this way you can flush all the old fluid out of the rack and see if there is some sort of blockage in the system also
    Body by Holden, Soul by Brock
    the Legend will live forever
    Keesh's Avatar
    Jan 2006
    thats why they say do not overfill.. i did my high pressure hose too it was a pain in the ass to get it up and into the resevior haha
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    there is a power steering pump seal kit to suit on eBay for about $11. Maybe worth keeping one handy.....
    VS Equipe Series II
    Jan 2005
    Sorry about not getting back to you all.
    Turns out it was the 'o' ring at the top of the pump, where the reservoir sits on top. If you don't line that exactly, then it will leak. Got that fixed and everything is perfect. Apparently, so we've been told, it's a very common mistake made when changing them over.
    Thanks heaps for you replies though. Much appreciated.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yeap, that'll do it!! Also, for anyone else doing this, make sure you replace this o-ring with a fresh one THE RIGHT SIZE whenever the pump is changed Good chance it'll save you from having problems later on ...
    VP ute
    Mar 2006
    Useing Dexron III instead of II will reduce the amount of oil venting out from the top of the lid as well. The VN/P really could o with an oil cooler for the steering. It boils very easy and can cause premature failure. It is said that you can use tractor fluid instead to keep temps right down. I know that it can be used in Ford gearboxes too and gives very hard shifts with a long life span for the gear box, not sure on GM boxes though. Can be used in GM steering but.
    Keesh's Avatar
    Jan 2006
    power steering res. caps are a common leak and are still available from holden, i just changed mine and it seals nice! its always a good idea to get genuine o rings, so they fit correctly, youl be suprised if you new how many aftermarket parts look the same but never fit the same so play it safe.. good to see you got it fixed mate! i had a problem with the high pressure hose myself and its a pain to change over! at least it was something nice and small
    VN Calais 5L
    Dec 2006
    just while this thread is here, me and my dad are fixing the car up for roadworthy and a week before checking everything, we noticed it had a fairly bad leak of power steering fluid. after high pressuring underneath etc, we cannot find the leak! now this could be a good thing, but if it starts leaking when in for roadworthy check, we are gunna be pissed off!
    the old mans just getting a new high pressure hose for it, and we'll see how we go, but i might just ask him about the o-rings too and see what he says..
  1. Power Steering leaking.. ideas?
    By thekow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2007, 05:24 PM
  2. Power steering fluid leaking
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-06-2006, 07:58 PM
  3. VS Power Steering Leaking Badly
    By des in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2005, 01:31 PM
  4. leaking power steering and tyre wear
    By RufusŪ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2005, 10:09 PM
  5. Leaking Power Steering Fluid.
    By Lukie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2004, 05:40 AM
