Results 1 to 10 of 10
Thread: Battery Problems?
    VN Berlina
    Sep 2006
    Default Battery Problems?
    Hey Guys
    Twice in the last week my cars battery has gone dead.
    Once i had driven it for awhile got home at 1 went to drive at 4.30 and it wouldnt start
    The other time was tonight at the Vic Bushrangers game, parked the car went back and the battery was dead after about 2 hours.
    There was nothing left on or anything.
    Could there be an unknown problem??
    VP Exec,Gsx-R 750
    Mar 2005
    Is your alternator working properly? It could even be something handy like the boot light staying on or something, drawing current from your batt when the car is off
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i had the boot light doing that.
    also a chick i know just picked her panel van up after a respray that took months, and the battery won't hold a charge, sometimes they just get that old
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    if a battery goes completely dead twice - ditch it! it wont ever work the same again, when a battery goes flat it damages the plates inside.
    so id be getting a new battery and making sure the alternator is charging it adequately.
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    ivaninoz's Avatar
    ivaninoz is offline Ivaninoz
    VS SerIII Statesman
    Nov 2006
    Millmerran, on the Downs, Darling
    Question
    What Voltage is the ALTERNATOR putting out?
    Under Minimum Load,
    and
    Heavy Load...Head Lights and High Beam?
    That'll give some indication.
    Ivan in Oz,
    Over the Hill, SEQld
    MOTOGuzzi T4 and Cali III Dresser
    1985 735i Bemmer............
    1998 Statey......
    VP
    Oct 2006
    Adelaide, Blackwood
    vp exec
    Dec 2006
    vaucluse, sydney
    Before you ditch it there are a couple of simple things to check:
    1. drive belt tightness - should flex 1cm either side of the rest position. normally not aproblem with the built-in tensioner serpentine belts.
    2. battery fluid levels (in normal lead acid battery). The acid should be up to the bottom of the level built into each cell.
    3. battery clamp tightness and cleanliness. All connections should be tight and free of corrosion.
    If the battery is 3+ years old it is probably stuffed.....
    cheers.
    VN Berlina
    Sep 2006
    Quote Originally Posted by peter65 View Post
    cheers.
    Thanx mate, went to tighten all the clamps the other day, ended up buying some new ones just to test it out and not one problem since!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Dont forget to put some grease on the terminals to stop anything building up on them!!
    and 3 Dangerous non ABS VN's
  1. More Battery Problems
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 02:48 PM
  2. Battery Problems - Help Needed
    By hsvp57 in forum Electrical Wiring / Questions
    Last Post: 07-05-2006, 12:06 AM
  3. battery problems
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 02:49 PM
  4. battery problems
    By jerzey1234555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2005, 09:45 PM
  5. More Battery Problems
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 14-07-2005, 05:53 AM
