Results 1 to 10 of 10
Thread: Indicators not working but hazards are?
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default Indicators not working but hazards are?
    Hi all,
    I have a 1992 VP Berlina and suddenly today the left and right indicators are not working at all. No noise or anything comes up on the dash, or on the actual indicators themselves, but if I press the hazards on they work! So I am totally stumped as to why its not working. Any ideas?
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    im taking a guess that it would be the indicator stalk has worn the contacts away, so it isnt switching the indicators.
    the hazards are seperate to the indicator stalk, so they will work unless the hazard switch dies, but since it rarely gets used, i dont think it will ever die.
    goto the wreckers and try and find a working stalk, or you can buy them aftermarket from places like autobarn, we keep a few on the shelf usually. but i cant remember the price.
    SiLeNt-SoN's Avatar
    SiLeNt-SoN is offline 2000 WH Statesman
    2000 model WH statesman
    Sep 2006
    just check ur fuse's.. i had the same problem, and i found out my indicator fuse was busted, yet my hazards worked fine.... Just something small and easy to check dude!
    WH STATESMAN
    1990-VN
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Only leaves dodgy flasher unit or wiring fault as the culprits then
    If ignorance is bliss why aren't there more happy people around ?
    hakhawk's Avatar
    Jan 2005
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    ok, thanks for that guys, looks like a trip down to the auto elecs for me...
    VN Calais no more
    Sep 2006
    on the VN, the fuse for the indicators and hazards are seperate, but the indicator fuse is shared with the windscreen wipers.
    I found this out when a wiper got jammed and poped a fuse and i lost indicators, bit still had hazards.
    Check if your wipers work too. if not - replace the fuse, 15A.
    Other than that then a likely culprit could be the indicator stalk.
    Dont like my driving? Get off the sidewalk!
    1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
    VR Statesman, WK Statesman
    Aug 2006
    Just guessing here, but it wouldn't be unheard of to have separate flasher units for indicators and hazards....
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i had something similar, no high beams. holden dealership said it was the combo switch and quoted something ungodly to repair, got a new one from the wreckers, didn't fix it so i chucked the old one back in (less worn)
    when i checked, the fuse was fine, but i took it out, noticed some gunk on the terminals, after cleaning that off, they worked fine.
  1. Indicators Arent Working HELP!
    By jungl3boy in forum Electrical Wiring / Questions
    Last Post: 03-01-2008, 10:32 AM
  2. VT indicators not working when cold ????
    By BOGANV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2007, 09:24 PM
  3. Help! Vr Indicators, Hazards + Wipers Not Working!
    By Summer-Sickness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 06:41 PM
  4. Indicators Not Working?!
    By 1991_Vn2nV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 06:07 PM
