Results 1 to 14 of 14
Thread: how long
    vq statsman..5lt
    Dec 2006
    nsw
    Default how long
    can somone tell me why the touqre converter or harmonic balancer would vibrate the car badly and why the converter would do this can it be dangers and how long till it could fail....(years months) as my kids travelle alot in it ty
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    it won't be the converter, it'll be the flex plate the converter is bolted to, they can crack and come away from the crank. if it's vibrating badly i'd suggest getting it looked at if your not keen on getting under the car yourself and removing the inspection cover and having a good look at the converter/ converter to flex plate mounting bolts and flex plate itself for cracking/damage etc. you'll need a good lightsource as it can be difficult to see.
    Body by Holden, Soul by Brock
    the Legend will live forever
    vq statsman..5lt
    Dec 2006
    nsw
    ok thanks heaps i was thinking of taking of the inspection plate to look but wanted info first ill look tmrw.......i dont know muck about autos (manauls yeh)if its not loose or cracked any ideas
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Centre bearing/uni joints can have some vibrations. While your under the car looking at the tranny give the tail shaft a good riggle n see if it moves around at all.
    and 3 Dangerous non ABS VN's
    vq statsman..5lt
    Dec 2006
    nsw
    as i said it vibrates when stoped as well in park..neutral and one the drive and ive done both unis also ...thanks for the idea
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by vq_statss View Post
    Tape a 500 gram lead weight to the wheel of your bike and go for a ride. Even at medium speeds your bike will be nearly impossible to ride. How long it will take - impossible to tell. Could last months but then again the bearing might fubar next time you start the car. It all depends on how far out of balance things are and how good things were to begin with.
    Reaper
    vq statsman..5lt
    Dec 2006
    nsw
    reaper thanks for the info....what bearring u talking about.....it does it stationary aswell
    Reaper's Avatar
    Aug 2004
    Sounds like you are on the right track. If it vibrates in park the problem will be in front of the transmission and most probably won't be the tail shaft.
    Reaper
    vq statsman..5lt
    Dec 2006
    nsw
    took inspection plate off box checked flex plate and torqe converter not loose or cracked looks prety clean in there............harmonic balancer u think?
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Harmonic balancers are pretty common issues in these cars. It will cause rough running and shaking depending on how bad the problem is. Not overly expensive to fix, or overly difficult either.
    Life's Grouse in Frankston South!
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    have a look at it, are there any cracks in it/ chucks missing, how bad is the vibration?
    Apr 2006
    Auckland NZ
    to check the harmonic balancer, do the visaul thing, then remove the serpentine belt and swing off the thing and see how much it moves, it shouldn't really move/deflect much at all
    vq statsman..5lt
    Dec 2006
    nsw
    visualy it looks ok.....the vibration is bad (my 22 year old deisel landcruiser has less)1500rpm seems to hum in and out the vibration.nothing is touchin the engine.im 99% sure its not a miss.could it be in the engine .it runs smooth and quite heres the funny thing put hand on the engine u dont feel vibes at all.even throw the auto shifter.bad on steering wheel and u can feel it throw the car.graham
    VP Berlina V8 / Toyota Hiace
    Oct 2006
    SA - North
    Could be the bush in the front of the trans, where the converter meets.
  1. How long will you keep your car????
    By AttaBoy in forum The Pub
    Last Post: 09-03-2007, 05:23 PM
  2. how long?
    By HoZy in forum Car Audio
    Last Post: 22-03-2006, 09:51 AM
  3. Vt long trip
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2006, 01:50 AM
  4. how long will it last
    By mutant in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2006, 02:56 AM
  5. How Long Does It Take !!! ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2006, 08:42 PM
