Hey Everyone, Just replaced the diff in my v6 calais,and now the tailshaft is kinked down about 40 degrees at the c.v. joint. I have tried using another tailshaft out of a 5L irs (mine is live axle) and it's still the same. The car is on superlow king springs. Do I need a spacer where the tailshaft bearing bolts up underneath the handbrake?? The panhard bar is still stock. I have put the original tailshaft back in for now, it was ok before on the old diff. Any ideas would be great. Cheers Dan
yeah the center bearing has a spacer. it is only about 10mm thich tho shouldnt make 40 deg difference do you have the bracket that holds the ccenter bearing to the car or is it just hanging there
13.3 1/4 exhaust only untuned!
for it to sit at a 40 degree angle u mustn't have the bracket that holds the center bearing on there or u have it upside down if it will fit in the wrong way round..
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
yeah, i'd suggest looking at the center hanger bearing mount
Body by Holden, Soul by Brock
the Legend will live forever
Thanks for the quick replys, the centre bearing bracket is done up the right way, I might have to check out a spacer. I'll take it out and try again tonight. Cheers Dan.
which way is the center bearing bracket sitting? with the loop up or down?
- Lou Holtz
Yeah I had the tailshaft upside down with the loop to the bottom. Maybe I shouldn't rush things in the heat. Cheers everyone thanks heaps, Dan.
