Results 1 to 4 of 4
Thread: VP running crap when hitting 1700-2000rpm
    VY V6 Acclaim Wagon
    Dec 2006
    Default VP running crap when hitting 1700-2000rpm
    Hi all, just recently i replaced the O2 sensor in my car but since then its been running like a bitch when going through gears around 1700-2000rpm but only on GAS, petrol no probs but the gas worked fine before. at that rpm range it sound like the engine isant getting enough gas because it feels like it going to stall but if i back off then dump it it runs good. Could it be that the O2 sensor is ready the exaust incorrectly since LPG is running, i herd that O2 sensors dont work properly when running gas, is this true? one last thing code 13 is comming up again what does this mean exactly? cheers
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    is your converter freezing cos if it is it will restrict gas flow.
    and i dont think the gas uses the o2 sensors at all, only petrol.
    not sure about code 13 ill just go and look it up.
    We got rep back, yaaay!
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    code 13 is no o2 signal, could be that the sensor wasnt wired up right?
    VY V6 Acclaim Wagon
    Dec 2006
    i checked all the wiring and it all A OK and found out that the line from the grounding lead on the O2 sensor isant following through to the correct cables on the computer plug D1 D3 D6 and D10. I tested this by unpluging the o2 sensor and using the continuity tester on my multimeter and i didnt get a signal at all from the plug to those points but i do get a circut if i ground one end and probe each point on the plug, is the o2 connector ment to go to those points at all cause it says it does in the workshop manual. Also i check the signal lead VOILET wire and it is working fine so grounding may be the issue. Also i have a telgas 5000 gas computer and it actually taps in to the O2 sensor signal wire so im guessing it may read the o2 levels, what u's all think?
  1. red vn executive $1700 as is (MELBOURNE)
    By leon archer in forum Vehicles For Sale
    Last Post: 03-05-2007, 02:15 PM
  2. filled up at BP now running crap
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2006, 01:52 PM
  3. under 2000rpm
    By commod8 in forum General
    Last Post: 01-09-2006, 08:25 PM
  4. Vl 4 Sale Sydney $1700
    By vl rb30 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-11-2005, 11:08 AM
  5. +++vl commodore 4sale $1700
    By vl rb30 in forum Parts And Other Items For Sale
    Last Post: 23-10-2005, 09:38 PM
