Results 1 to 8 of 8
Thread: Clunking when turning...
    VN Calais no more
    Sep 2006
    Default Clunking when turning...
    Yes, another problem with the calais... :P
    Im hearing a noise when i turn sharp left corners.
    When i turn right, no noise
    when i turn left from stop, no noise
    when i turn left at speed theres a knocking noise from the back left corner of the car, almost sounds like a loose shocker.
    Any ideas?
    Wheel sits solid on the hub and doesnt move, visually the suspension components seem fine.
    Dont like my driving? Get off the sidewalk!
    1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
    Vn
    Nov 2006
    Glen Iris, Vic
    Are you sure the sound is coming from the back left? the reason i ask is because i just had a similar problem only when i turned left hard. took the front wheel off and had a look at the swaybar links, which stabalize the steering. Turns out its a common problem as the bar is straight it put to much pressure on the rubbers between the swaybar and the strut and it pushes the rubber down causing the swaybar link to come up to far when doing sharp left corners and it hits the top of the strut. new swaybar links are slightly bent to stop to much pressure being applied to the rubber.
    hope this helps.
    VN Commodore
    Feb 2006
    when i had my old vn years ago it use to do that. when i sold it to a mate he said the steering rack was buggered
    so it could be that too
    EDIT
    just read it over again. mine was more of a clunk. and that was it.. sorry...
    VN Calais no more
    Sep 2006
    definitely in the back end...
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    there is a sway bar in the back also, which also has link arms and rubber bushes that get flogged. same as the front, fit some nolathane bushes if thats the problem. check the front ones as well while your at it.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN Calais no more
    Sep 2006
    yeah, the noise is happening more often now...
    I guess its a good time to get the back lowered, chuck some new shocks on and replace the swaybar bushes maybe.
    I wont be able to do that for a few weeks, in the mean time i hope the wheel doesnt fall off. haha.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    nolathane ftw ^^
    The 1972 HQ Kingswood
    VN Calais no more
    Sep 2006
    Also worth mentioning is that it only makes the noise under braking or decelerating, if im accelerating through a lefty corner it makes no noise...
  1. diff clunking
    By vycommyute in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-05-2010, 10:53 PM
  2. clunking noise when turning left
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2010, 10:22 PM
  3. Clunking
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:06 PM
  4. clunking when turning
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 03:39 PM
  5. turning clunking
    By alex88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2006, 11:12 AM
