Results 1 to 4 of 4
Thread: remove the radio head
    vn executives
    Sep 2005
    Default remove the radio head
    hi, guys, I got a new redio head from a Landrover and wona change my in the VN. is this possible and could you please kindly show me how to remove the old one. many thanks.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Have a search around, I think there's quite a detailed guide on how to do this somewhere on the forum. Also, unless you have the manual for the Landrover head unit, you could come into some problems pairing up the wires correctly
    edit: Complete VN,VP,VR,VS,VQ,VG Headunit Guide [56k warning]
    The 1972 HQ Kingswood
    vn executives
    Sep 2005
    hi, I notice it is very complicated and requires a lot of coffee drinking, so maybe I could not afford it. thanks anyway.
    vp exec
    Dec 2006
    vaucluse, sydney
    hey there. i just put an eclipse head & amp in my vp... and it went in sweet.. the issues you have to deal with are:
    1. pohysically mounting the head. if its a DIN head (most are) thats cool - use the sub brackets off the original radio, put new holes in to suit the new head (its safer to drill new holes in the old brackts to suit the head than vice versa) and screw it in to the existing dash mounts.
    Electrical/speakers. depending on who makes the head (most are made by one of a few big brands and then "rebadged" with the car makers name). Supacheap have common wiring adaptors to match the radio maker to your standard wiring (its worth the expense for one of these so if you want to sell the car you can slot the old radio back in easily). if you cant get one of these you have to match up the wires. if you have a book for the car it tells you what goes where on the car side. Most radios are standard too. its worth the effort.if you want more info ping me. pulling the dash to bits is fun.
  1. Can Some one tell me how to remove the Head Unit in a VY or VZ??? THANX
    By commodore_vy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-10-2009, 08:32 PM
  2. How to remove radio VY
    By milka in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-04-2007, 03:20 PM
  3. Do I have to remove head unit?
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2006, 02:27 PM
  4. How do i remove the stock Head Unit in a VZ???
    By commodore_vy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-07-2005, 12:18 AM
  5. Easy Way To Remove VT Head Unit
    By Ant in forum Car Audio
    Last Post: 26-06-2004, 08:47 AM
