hey all how many people have to constanly have to fix there dam window regulaoitrs on there vn
is there a fix for this at all i have owned 3 vn with all the same problens on em
so you should be a expert at fixing it then huh?![]()
.:Blown VT V6, DAJ37:.
What do you mean by fix? The regulators get strained and flex in the middle as the runner tracks get fowled up. The felt slipy things slip out of place.
Glue the felts into place and use scilicon spray in the tracks.
Takes the strain off the mechanisim.
and 3 Dangerous non ABS VN's
My VP does the same. the felt bits always slip down on the drivers window. I just get sick of the rattle and glue it back every few months.
Life's Grouse in Frankston South!
thats alright..... my mech is missing about 3 teeth..... i have to wind up to half way then lift the glass while winding to get it past the broken point...... morale of story is try wind the windows up and down before you buy!!
is it a mission to change the whole guts out? ive done it to a vl before and guess holden wouldnt have changed much.....
Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
The regulator is held in by 4 rivets that end up moving around a bit. 4 nuts n bolts stop the movement and hold it nice n tight. I think I just undid the front channel 2 bolts and slipped the window out. Drilled the rivets out. New bolts and wolla. All fixed. Took about 1 1/2 hours all up.
Use super glue on the window rubbers - the one on the outside of the door frame that slips into the window grove and binds up the window. I dont have the problem anymore and whished I'd done it years ago - very good fix.
Do the job when your not going to drive the car for a while and leave the window up and look to see its all in place.![]()
yup cool sounds just like the vl 1 i did, hahaha bloody pin broke on the utes door hinge last night..... oh the joys of motoring
