Results 1 to 20 of 20
Thread: Bypass immobiliser without key??
    Bungle's Avatar
    Bungle is offline Bungle
    VP Exec S2, VZ Exec
    Jun 2006
    Default Bypass immobiliser without key??
    Does anyone know how I can turn my immobiliser off without the key ?? It never came with one when I bought it.. I know i'll probably have to end up going to a locksmith or Holden for a new key, just wanted to check if I could do something myself first...
    Cheers..
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    open passenger side door and on the chassis bit is a little switch thingo for the immobiliser so you can turn it on/off.
    Bungle's Avatar
    VP Exec S2, VZ Exec
    Jun 2006
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i suppose you could try to get the keyhole out, and just cross the wires it connects to. though i'd hope there's more to it than that.
    VP Berlina V8 wagon
    Jan 2007
    Wild West
    I know it might sound really dumb, but try any key. Mine turns with any old key! Got rid of the factory immobiliser anyway as it was playing up.
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    if you want to drill out the cover plate, it is reasonably simple to get to the back of the override switch. There are threads here that talk about this in detail, and unfortunately, it is rather easy to bypass the immobilizer this way. (especially if you have two switches, one switched to 'on', and the other switched to 'off') I'm going to get a key cut eventually now that i have one switch removed from the car! Good luck.
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Quote Originally Posted by Bungle View Post
    Cheers..
    Seriously, I'd just get the key cut. Cost me $30 bucks or something (before the $110 for the remote), that way you have options.
    Life's Grouse in Frankston South!
    Oct 2006
    Kingston
    do you reckon they show the rivets pics of angelina jolie at the factory to make them hardened?
    fazz1977's Avatar
    Aug 2005
    VP Berlina V8 / Toyota Hiace
    Oct 2006
    SA - North
    easy to by pass if you know how to. Its pretty hard to explain.
    If your really keen i can tell you how.
    vx ss
    Oct 2008
    all you gotta do is join the pink wire at the ecu to an ignition supply that will do the trick
    VR commo Wagon
    May 2009
    turn key on and wait 45 mins this over rides immobiliser just need a handy 45 mins spare before u leave to go driving may as well polish ur bundle of joy easy but annoying? hope this may help
    vn
    Jul 2009
    I have a toyota lexcen and the immobiliser will not turn off anymore and I don't have the key for it. I have tried the 45minute way and it doesn't seem to work. Does anyone know of a simple way to turn off the immobiliser? if not some instructions for the hard way..
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Quote Originally Posted by dazzanz View Post
    thats what i did for my drag vp no need for the s1 vn thankfully
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  15. #15
    VL 5L inj
    Sep 2007
    Woodburn, NSW
    yeah its quite easy, theres 4 wires that go to the key, two wires join when the immobiliser is ON to make the dash light flash, the other two join when its OFF to make the car go.
    you will have fun drilling out all the rivets to get at the ecu and wiring though.
  16. #16
    vn ss 355, vl, vr, vs ss
    Jan 2010
  17. #17
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by fazz1977 View Post
    Agreed but I am probaly biassed
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
  18. #18
    Holden vt calais 5 litre
    Nov 2007
  19. #19
    Jan 2010
    can u tell me what 2?
  20. #20
    Commodore Executive
    Apr 2012
    Papakura
    Me too please I'm buying a car off of Trademe ( NZ ) and the fullah I brought it off lost the main keys with the chip or rather on it and I need to figure out a way to get it from Tokoroa ( NZ ) to Auckland ( NZ ) getting it towed isn't a option so if I can get it started with out the Immobiliser then it will be okay till I get the Body Control box I ordered for it...
  1. VS hot water bypass
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2006, 09:26 PM
  2. EST Bypass or test?
    By iroczinoz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2006, 11:33 AM
  3. bypass valve
    By Mazzone_Child in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-01-2006, 02:32 AM
  4. aircon bypass instructions
    By jafo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2004, 10:36 PM
  5. bypass
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 10:41 AM
