Results 1 to 11 of 11
Thread: VP Dash Wireing
    Jan 2007
    Default VP Dash Wireing
    Hi All,
    I have a VP comma and putting in a level 2 calais cluster dash in place of my normal vacationer dash.
    ok want to be able to use trip computer etc..
    i have all set of new left and right button blocks and noticed wont just plug in they are different to what i have
    3 plugs on left and 2 on right but calais are reverse and 2 buttons different.
    i was asking if anyone had a full wireing diagram for a vp so i redo to suit new calais blocks + doing connecter 4 on dash.
    vas
    VP
    Oct 2006
    Adelaide, Blackwood
    Jun 2005
    vp calais dash is a bitch because you have the bcm to deal with
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Jan 2007
    thankyou SpOtteh, i have it already, i thought for vn not vp.
    @stocky you mean just running a new cable for con 4 for the dash ? or more you mean ?
    thanx for the help
    vas
    Jun 2005
    Quote Originally Posted by vanastasis View Post
    thanx for the help
    vas
    when installing a vq stato dash into a vp exec i ran into a few problems. the vq switchblock had buttons that didnt click in. they sent a signal to the bcm instead. the vp exec switchblock has buttons that stay in once pushed. when i installed the vq switchblock, the dome light, and whatever other buttons were on there, no longer worked without a bit of modification to the wiring. this was a few months ago so i cant remember what i needed to do to get it working
    Jan 2007
    all my buttons are solid state when u press they go in except the trip buttons and cruise buttons & antenna
    its a vp calais dash with surrounding blocks
    i checked already little different to what i have
    and i have a vacationer which is like a S pac with elec windows cruise etc...
    i already have dimming light after exit car, 10-20 secs light turns off (standard)
    dash works 100% straight in except had to change plug 1 pin 10 to 11 for left blinker and works fine with standard blocks,
    dont want to risk putting other blocks in until i know cause they different and don't want to fry anything. thats why after complete wireing diagram for vp calais and vp vacationer so i can modify without frying it
    thanx for quick reply
    vas
    Jun 2005
    easiest way is to take the new dash and the old dash, look at the back of each, and see if they both match up. you will see sections on there where they say which pin on which connector does what
    Jan 2007
    ok cool
    but that part is fine (except speed sensor via ecu error) fixing
    my problem is only the blocks wireing. (left & right)
    vas
    Jun 2005
    i get the speed sensor problem as well. its probably due to broken lines on the circuit board on the back of the dash cluster
    VP
    Oct 2006
    Adelaide, Blackwood
    i done this in my vp (put in a vn calias dash) and yea i had the issue of my exec dosnt have a bcm but the car i ripped the dash and switch block out of did, i ended up keeping the ond circuit board from my old switch block and bridging it to the new one so i got the light delay.
    with your switch blocks, pull them apart and if your any good with electronics follow each track on the board and see where it goes, then just compare with your old switchblock and 'break' or bridge any tracks that need changing.
    gl
    Jan 2007
    thanx heaps guys, i think me doing the dash itself was fine and easy
    i booked it in tomorrow morning with autoelec (mate)
    he'll fix it up, he does this all the time,
    keep you's posted and thanx again for help
    vas
  1. vb sle wireing
    By vtcommodo3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-01-2007, 09:14 AM
  2. Wireing harness
    By maginoodle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 08:05 PM
  3. Vx horn wireing need help
    By Decksta in forum Electrical Wiring / Questions
    Last Post: 05-09-2005, 08:15 PM
  4. Vs ecotec BCM wireing
    By chevyv8 in forum Electrical Wiring / Questions
    Last Post: 29-08-2005, 06:16 AM
  5. Wireing up a Vk Digital Dash to a vn Loom
    By Aurc_2 in forum Electrical Wiring / Questions
    Last Post: 16-03-2005, 09:02 PM
