Results 1 to 14 of 14
Thread: I cannot be buggered searching
    Jul 2004
    Default I cannot be buggered searching
    Ive had it on the dyno and laptop trying to figure it out. No sensors are playing up so im guessing its electrical.
    I can be driving for a while or just out of my drive way down the street and then the car turns off. Either as i am hitting a corner or sometimes at the lights. When in reverse or drive it almost stalls as well. In nuetral it is fine but drive and reverse it drops to about 600rpm.
    When the car turns off the electronics stay on but the engine cuts out.
    While on the dyno it was running fine and didnt stall once which was kinda crap.
    I am guessing its something simple trying to annoy me.
    Any idea's?
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Reset your ECU, pull the battery for 5 minutes, put it back on, start the car and rev to 3000rpm for 10 seconds. See if that helps. If there is still an issue it will start being recorded in the computer again.
    Life's Grouse in Frankston South!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Try a different ECU - fixed my stalling issue.
    and 3 Dangerous non ABS VN's
    fazz1977's Avatar
    Aug 2005
    There's always that option too. ECU and memcal.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'm assuming that with the laptop you been loging fault codes etc?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Jul 2004
    yeah, the laptop is logging all fault codes, i am missing a spark about every 100 but thats probably normal, other than that no errors or problems known by the ecu etc.
    I was hoping it was a oxygen sensor or something simple.
    I tried resetting the ecu and that didnt work, i just changed the ifm sensor but left the ecu the same for now.
    The engine has only done 4610km now, i probably forgot to do up a bolt tight enough or something stupid. Could it be anything like that?
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    My SS was doing the exact same thing, was a dead ECU.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    5spd VN SS
    Jun 2005
    Does it have anything to do with the vacuum line to try and keep it idling?
    kilowatts are like drugs, the more you get, the more you want.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by str8up View Post
    If you're talking about the map sensor vacuum line, then his data logging would have definitely noticed that. Actually, all vacuum lines will produce a noticeable effect if removed. Apart from the charcoal canister lines and they're just silly.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    stupid question but tried cleaning out the throttle body and replacing gaskets etc? but it just 'dieing' could be crank angel sensor? dont always report error codes
    VN Calais 5L
    Dec 2006
    my dad had a stalling problem in his hilux 4wd, which had the 3.8 L commo engine in it, and it was a sensor problem. does your car have trouble starting again once stalled? if so, get a bucket of water and tip it over the motor (i know it seems odd, but try it and see what happens).
    if the car runs fine after this then its the sensor, if my theory is right ill get more info for you.
    Jul 2004
    ill replace the ecu and see what happens.
    I have replaced the crank angle sensor etc and all seems fine so we shall see.
    Cheers for that
    Jul 2004
    well to my amazement, it was simply the throttle cable.
    When i turnt around corners it pulled the cable with a tie i have holding it and when it was at the lights etc it was slack so viabrated.
    I bet no body thought of that. haha
    cheers anyway, have a good night
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by Ipswitch View Post
    Dang, thats an odd one. Glad you found it.
  1. New VZ Buggered
    By 88GreenVN in forum The Pub
    Last Post: 22-12-2007, 11:40 PM
  2. Searching
    By ivaninoz in forum The Pub
    Last Post: 16-01-2007, 07:27 PM
  3. any one searching for a....
    By warney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 03:18 PM
  4. searching to buy
    By onesaucylady in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-10-2005, 08:11 PM
  5. Im searching for the new VZ tv ads.
    By Andiesrefuge in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-04-2005, 04:48 PM
