Results 1 to 5 of 5
Thread: any pro spray painters here???
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default any pro spray painters here???
    hey, im going to be doing some touching up of my paint job as ive damaged it, cracked bumpers and that usual stuff that happens from doin 120 sideways down a gravel road...
    now ive got alot of stone chips and that crap on the metal paint, being metal its rusted, when i sand it out what should i do, use primer/filler, or prime the metal and overlap it onto the paint, then give it a fresh coat over the top, ive done a fair ammount of painting but only when its been all primed, no repair work..
    also is it possible to get chrome paint, im looking at chroming the black door strips on my car like on the series 2 calais,
    my front bumpers rooted (LOL) kinda rolled it into a big rock, hit a few too many gutters backing out etc, the usual crap you do with a lowered car and bodykit...
    the whole car is going to get a fresh coat of paint (apline white on top insted of faded ass white)
    any tips???
    VN Calais 5.0/vy sv8/r31 rb20
    Oct 2006
    sydney
    if you go back to metal you should use an etch primer first, though if u sand them out and paint it, it will look all rippley when you look down the car so you will have to bog it and sand,bog it and sand and so on until it is perfectly flat and just remember it may look ok but it wont feel ok so always run your fingers accross the bog after u have sanded to make sure you get it right. it also helps to put a test coat ova it wen sanding is finished cause that will bring up any faults in your work straight away and you just lightly sand it off when your ready to prime. hope this helps
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Treat the rusty spots or it'll come back later!!! The use of a mist coat over the repair area is a good idear. Use a light coat of a darker colour (I do mean mist coat) onto the undercoated repaired area. block off with wet 600/800. You will see any marks then that need further work.
    and 3 Dangerous non ABS VN's
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah thats a technique ive done previously, cheers for the help the rust isnt bad, its just like a few spots on the stone chip
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    im thinking of going black now.. hrmmmm
  1. Replies: 21
    Last Post: 30-09-2007, 11:56 PM
  2. Spray painters in Adelaide NorthEast Area
    By Clinster in forum General
    Last Post: 08-03-2007, 02:42 PM
  3. Replies: 4
    Last Post: 23-09-2006, 03:21 PM
  4. Spray Painters
    By Robbie in forum General
    Last Post: 20-02-2004, 03:16 PM
