Results 1 to 6 of 6
Thread: not good
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    Default not good
    a few days ago in my injector cleaner post i told people that after replacing my earth strap fixed all my problems and it made my car run good, since then ive only driven it twice and its fuxxzored. all contact points are clean and its on really good, but now the car is running really poorly and the headlights are flickering like the problem i had before i replaced the earth strap.
    also if u put indicators on u can see the arrrows flickering same with park light. this car is driving me insane. what could be wrong now?
    Burt_vn's Avatar
    Burt_vn is offline Back in the game
    VG V8 5spd, 400hp 5spd soarer, vq stato
    Jan 2007
    Gold Coast
    It still sounds like a dodgy earth. Have you checked ALL of them? It is an interesting problem, considering its doing it on multiple circuits IE, headlights indicators and your cars running poorly. Im not sure i can help you mate. sorry.
    VG ute, 5.0lt, 5spd, twin exhaust, cam etc.
    VQ stato, 5.0lt, auto, pretty stock
    TT Soarer, 400rwhp, 5spd, lots of mods.
    VN S Pac VH SL/X
    Jul 2006
    check how much voltage your battery is getting. It should be getting above 13 volts or so. (alternators charge at 14.4 volts but lose it due to the resistance). Im only guessin this due to the lights. Good luck
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    dude, charge at 14.4V???
    may aswell say a 9V battery puts out 9.00834v
    off the battery voltage should be round 12V-13v, while running it should be anywhere from 13.5V-14.7-8v i think is what the regulator limits it to
    alternators are belt fed therefore the charge is related to RPM, we all know voltage isnt currnet :P therefore it could be charging at 14v and putting 0.050mA through
    get a multi meter on and test as the voltage is a indication of if its charging correctly but to know if its really blown you'll need to see a auto elec, i DOUBT its a alternator issue
    when batterys die they just tend to stall the car/not start
    have you checked your battery terminals mate??
    when i forgot to ground my coils properly (bolt was loose)
    it wouldnt go above 3000rpm and ran really rough
    sounds like a grounding issue, make extra grounds from coils, block everywhere
    however my brother had the same issues when his ECU died,
    VN S Pac VH SL/X
    Jul 2006
    just saying what i learnt from a auto electrician when i did work exp there for a month
    pr0n's Avatar
    03 VY II S V6
    Dec 2006
    Gladstone
    the battery is fine and the alternator is putting out the correct current.
  1. good turbo to acheive 500 bhp and $880 good price for vl 5litre diff??
    By cxcxcxvcvcvc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-02-2007, 10:33 PM
  2. Ebay racing seats? any good? good to sit on?
    By phat_com in forum General
    Last Post: 18-12-2006, 02:55 PM
  3. Good Buy or Not
    By BeastVS in forum Car Audio
    Last Post: 19-10-2006, 01:12 PM
  4. Engine additives, good or no good?
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 08:31 AM
