Results 1 to 21 of 21
Thread: welsh plug
    VN Commodore
    Feb 2006
    Default welsh plug
    has anyone done a welsh plug on the back of the right head. what i was wanting to know, is, if it is easy enough to replace without pulling the head off or the motor out. as i really don't feel line doing that right now. my car has been off the road for a month and a half now while i have been doing my turbo conversion and i want to start driving it again..
    i am in two minds about it all. well 3 to be honest. either pull the motor out and do the welsh plug and the rear main while it is out, pull both heads off and get them ported a little. or just see if i can do the plug while the motor is in the car. there looks to be a little room but not too much..
    any ideas let me know..
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    you should do all welsh plugs at the same time... If you got the right tools it can be all done in a days work unless you get head work done.
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
    VN Commodore
    Feb 2006
    i reckon welsh plugs are a piece of piss to replace. i am thinking i might do all of them. still not sure though..
    i also wouldn't mind just doing this welsh plug and then rebuilding another down the track motor for it.. but then i would have to find another manual crank.
    then again i should just do all the welsh plugs cos it would be a long time till i get another motor built
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    lol a good days work???
    where are they all located???
    i know the heads have a few of them but where else???
    VN Commodore
    Feb 2006
    in the block. i think there is 3 each side. and there is some at the back of the motor. you can only get to them by taking the motor or gearbox out.. it would take more time taking the motor out and putting it back in than doing the welsh plugs. it is a pretty easy job.. i just don't want to do it.. too lazy
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    agree'd defa, my turbo should be done soon bout a week and some more welding should see hte manifolds done
    VN Commodore
    Feb 2006
    well i got the welsh plug out. took me ages to get out. i haven't see one stuck so bad before. and that fact that it was very hard to get to.. so tomorrow i wiull get a new plug and my car will be going
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    do them all seriously
    put a flat screw driver on the bottom and hit it out so it comes side ways then pull it out
    Go Here --->
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    unless somebody has allready done the easy welsh plugs you should do all of them at the same time, as you can bet in the next few weeks the other side will start to leak. They all are made the same and use the same system so as a general rule they all seem to stuff up around the same time.
    There would be nothing worse than going for a trip/long drive and the other welsh plug on the other head lets go
    Just a thought
    VN Commodore
    Feb 2006
    yeah you are right. but i am not going to do them.. one went 3 years ago on the front of the right head. and how the one on the back of that same head. i might do them down the track but for now i won't..
    by the way i tried to hit it side ways but it was so bloody tight. i got it out by putting a hole in it with a punch then putting a bolt in it and screwing it in then hitting it out.. then it came out sideways..
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    you'd have to give it a few decents hits dont damage the block obviously
    but line it up on the actual welsh plug and push it in.. it should turn and easy to pull out..
    can i ask why your not going to do them all. cause it will put mroe pressure on there if they were leaking and now sealed it will make another leak
    Go Here --->
    VN Commodore
    Feb 2006
    i am not doing all of them cos i am a bit lazy. well that and i have been spending a lot of time on my car lately and to be honest i just want to take it for a couple of little drives. i drive my work ute during the week anyways so i don't use the car much. i just want to finally be able to drive my car now it is turboed and intercooled.. but i think i will pull the motor out and do the rear main seal at some stage so i will do them all then..
    it is funny. i was looking at a motor i got in a bit of a trade for another motor and the bloke who owned the motor doesn't do any work himself, and i see he has only some welsh plugs replaced. i gotta say i would be ****ty if i took my car somewhere for a couple of welsh plugs and they didn't do them all..
    i have two other cars i really want to work on also, so i want my commodore drivable so i can get back to them.. one has been on jack stands for over 6 months and is looking sad so i gotta get back to it..
    if i do anymore i will pull this thread up again so ya can so ya told me so.. hahaha
    VN Commodore
    Feb 2006
    well jstpozn you can now say you told me so. i have done a welsh plug at the back of the motor where belhousing covers up. so i am now in the process of pulling the motor out. i might go out soon and finish doing it. i un did all the bolts and stuff this morning just gotta undo the loom and pull it out now..
    Nov 2006
    Country Vic
  15. #15
    VN Commodore
    Feb 2006
    yes you did too... ha ha ha.. oh well. the motor is out now and all but the two welsh plugs i have replaced are out now. the two in the left were not leaking but one was soft. 4 out of the 6 in the block were fvkced. so yeah you all cursed me damn it.. but i am now glad the motor is out so i can replace the sump gasket and also hammer the sump out flat as it has a big dent in it..
    and there is 2 each side of the block not 3 like i said and there is two behind the bell housing
  16. #16
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    Yeah man.
    Once one goes and you dont fix it it puts more pressure on the others. Something i just regently picked up when learning engine re-builds.
    Thats the problem with engines.. You cant just do 1 thing and leave another most of the time it all needs to be done together...
    But anyways I wouldnt have thought it would have gone this fast thou
    Go Here --->
  17. #17
    VN Commodore
    Feb 2006
    me either. i thought i would get a few months out of the others. i can't believe how much they were just hanging on by.. nearly nothing.. but anwyays. live and learn
  18. #18
    redvr is offline adam
    vr executive
    Jan 2007
    Quote Originally Posted by defa View Post
    i just did that plug last night it look about an hour in car!!
    if its the passanger side head you can do it in car!
    all you need to do is take off the induction pipe and throttle cable and use a hammer to start with uyou cant swing it much but enough to get it.
    then when its flush you use a socket and rapped in a rag to hold it in and tap it in the rest of the way.. and your done!!!
  19. #19
    VN Commodore
    Feb 2006
    ya can get to all the welsh plugs on the motor except for the two on teh back of the two on the back of the motor. you either have to take the motor out or take the gearbox out.. i did all mine is about 20 mins with the motor out. i also did my rear main seal, which i am very glad i did as it was completly fvkced. the welsh plugs on the passenger side are a piece of piss when the motor is in the car. the drivers side back one is very hard. i did that one the other day while the motor was in the car..
    but anyways it is all done now, and hopefully the motor should be in tomorrow morning..
    and to all those people who told me so.. yes, you were right and next time i might listen a little better.. lol
  20. #20
    JSTPOZN's Avatar
    Dec 2005
    SA, North
    yeah but remember there are many ppl that wouldnt know whats what and just comment on it.. the only reason i saidsomething is when i went and got mine i was told not to do just a couple and im thinkin hes sayin it to sell me more... but yeah i asked ppl and found out thats the go... Did you get brass plugs?
    atleast now you know there all done aye
    Go Here --->
  21. #21
    VN Commodore
    Feb 2006
    yeah i went brass. i would never put a steel welsh plug in. and yeah, i am happy they are all done. it is a good piece of mind..
LinkBacks (?)
  1. 03-02-2008, 10:49 AM
  1. Welsh Plug
    By thad 5l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2007, 01:26 PM
  2. welsh plug problem
    By redvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2007, 10:04 AM
  3. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
  4. Left Welsh Plug Problems
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2005, 02:14 PM
  5. welsh plugs
    By Wonderboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 12:33 AM
