Results 1 to 12 of 12
Thread: Making flanges
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Making flanges
    hey, just wondering if anyone knows how to easily make flanges, if u got any tips
    i need to make 2x flanges as the turbo shops dont stock them and it will cost $115 to get them custom lazer cut ($95 setup charge for the image)
    soo i need to make one for my wastegate and blow off valve (might beable to buy the BOV one)
    im thinking 3mm thick mild steel, what shops can i buy a chunk of this from?? and how much??
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    is there a menzies metals near your joint?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nah dont think so,hakhawk reccomends using 5mm steel
    what tools can i use for cutting a 45mm hole???
    i could drill round the hole the port it all smooth with my die grinder??
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by PaRaDoX616 View Post
    Just find a small business that deals in metal fabrication. I just spoke to my sisters boyfriend, and he said with the plasma cutter at work and linishing all the edges would take all of 15 mins to make max.
    Selling FG G6E Turbo and buying a N/A Supra
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah, thats a idea, how much does it cost tho???
    any joints near eastern suburbs??
    still look at the flange man, take a 10mm drill peice, drill 4 holes and then get a drill round the circle and use a jig saw to finish the job???
    unfourntually im not going to be finished for the JC dyno day (turbo should be on however not tuned to a standard id be happy to put on the dyno and they'res sure to be issues), i would of if i didnt get defected but that was just unlucky
    ill make VSS dyno day
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Can still come along for a look on the day. Just look up ANY business that deals in metal fab.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah, its ages away tho, ment to be installing the turbo that weekend + im poor as hell
    VP Executive R-spec
    Jan 2005
    I you were keen enough for the flanges you could have made them with a hacksaw, drill and die grinder by now :P but it would only take 20 seconds to cut that out roughly with a plasma cutter and not much longer to smoothen it up
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Or another idea would be to take the flange and or the drawing to a small engineering shop would cost you like $20 or $30 tops. Or at home you could use a hole saw to get the large centre hole right. and just a normal drill to do the 4 holes on the corners
    Honestly it is not a hard job to do
    1 hr tops
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    go to a scrap metal place and ask for a pic of 6mm plate big enough, then all u need is a 45mm holesaw, drill, a couple of drill bits, and a grinder with a cutting and grinding wheels and a vice. mark it out on the plate, with engineering chalk or a fin tip nicko and center pop your holes, then put it a vice drill ya holes then cut it out with the cutting wheel then use the grinding wheel to round the corners and clean up any burs from drilling. then your down ready to weld it on.
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    VN Commodore
    Feb 2006
    those hole saws for metal aren't cheap. if you have a drill press or you can drill straight it would be easy enough to do all but the big piece ya self. after it is welded you really should face the surface as it may buckle when welded..
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah all gasket surfaces are gonna get worked even
  1. Making Bourbon
    By fleet5ltr in forum The Pub
    Last Post: 17-07-2006, 09:14 PM
  2. VC - Making 12v sources.
    By Goon in forum Electrical Wiring / Questions
    Last Post: 09-07-2006, 07:31 PM
  3. 2 inch steel exhaust pipe flanges wanted
    By craigvk in forum Swap / Wanted to Buy / Trade
    Last Post: 29-05-2006, 03:40 PM
  4. making her legal
    By hinterland in forum The Pub
    Last Post: 11-04-2006, 10:52 PM
  5. Making A Sub-box
    By adsVN in forum Car Audio
    Last Post: 21-03-2004, 12:29 AM
