Results 1 to 6 of 6
Thread: Smoking VN
    SiLeNt-SoN's Avatar
    SiLeNt-SoN is offline 2000 WH Statesman
    2000 model WH statesman
    Sep 2006
    Arrow Smoking VN
    Hey all...
    Big troubles, i drove my car today for about 10mins and it almost maxed out on the heat meter... waited till this arvo an went for another drive and after about 5 mins it started smoking like steam and heat everywhere? sounded like the overflow tank was boiling too...
    What are the possible reasons for this, and how much to fix?? lol
    any ideas welcome
    thanks
    WH STATESMAN
    1990-VN
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    probably needs a new thermostat and radiator cap to raise the boiling point of the coolant a bit...did you rupture any hoses or crack the radiator???
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    stuck thermostat?
    how's the coolant level? air in the system? (check the bleeder valve when it's pressurised)
    do a coolant flush/thermo replace. see if it helps.
    howto:
    How To Flush A V6 Cooling System
    SiLeNt-SoN's Avatar
    Sep 2006
    Yeah still unsure if i have broken any hoses or pipes yet.
    Just all day it was almost overheating and now finally it just started steaming! Im sure it has to do with the radiator but all oils and fluids are fine. Im taking it over to my uncles wreckers tomory, he thinks it may be a water pump gone, if so how much u think they are to replace??
    thanks
    WH STATESMAN
    1990-VN
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    dunno how much parts and labour on a new water pump is, but i'd exhaust all other options first, thermostat is ~$12 and the gasket is dirt cheap. they do go from time to time, so it could be that.
    VN Berlina
    Jan 2007
    Melbourne, VIC
    I replaced my water pump a couple of years ago, the pump and labour was about $150, but make sure you get a new pump. They are pretty easy to replace on your own too, with the trickiest part being getting the belt off and then making sure the cooling system has no air in it once you have drained it to do the pump.
  1. Smoking
    By VStooDie4 in forum The Pub
    Last Post: 27-03-2009, 07:53 PM
  2. no smoking in car
    By shumway in forum The Pub
    Last Post: 17-04-2007, 12:05 AM
  3. Smoking or non Smoking?
    By JD in forum Just Commodores Polls
    Last Post: 13-04-2007, 03:10 PM
  4. Help! Im smoking!
    By grosshom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2006, 12:29 AM
  5. Smoking.....
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2004, 05:23 PM
