hello ppl, long time reader first time poster. im not sure if this has been asked 1,111,3242 times before but would this work or could i change just the memcal instead . The vr motor is going in to the vn if this makes a difference
just plug up the VN wiring & use the VN computer & memcal, it will be fine
Rob
Thanks bob, i was thinking about something like that but was not sure about the loom compatibility . Cheers
will a vn/vp ecu plug straight into a vr? are the plugs the same? and will it run fine?
Thanx
When i grow up... i want to be young again
it will need some fuel pump wiring to get it going as the VN ECM doesnt support the BCM
