hey all i got 2 doors which i dont know if the electrics work now before i go and fit these doors is there any way to check that they work
If your existing doors have electrics already just make up an extension to go from your car to the new door and test it. Or you could power it up straight from a battery.
NO THE CAR DOESNT HAVE EM do u know what wrire is what tho
No I don't, but I would imagine the earth could be black, white or white with a black stripe. Then connect the other wires one at a time to the positive and try all the buttons to see what works. You shouldn't need to try every single wire just until you get window and mirror movement then you know it works.
