Results 1 to 11 of 11
Thread: Rear electric windows?
    91 Exec
    Jan 2007
    Kingsley, Perth
    Default Rear electric windows?
    As im sure you are all aware, VN Calais etc, generally only have front electric windows, is it possible to do a conversion on the rear windows to make them electric?
    VZ SS 5.7 M6 Silver
    Mar 2005
    I thought all Calais' would have full electric windows...That the standard option isn't it?
    91 Exec
    Jan 2007
    Kingsley, Perth
    Um, im not sure haha. I know my 91 VN Calais has only 2 front electric windows, rear are manual. And, ive seen photos of alot of other VN's on here that has the same. : /
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    WOW i thought all calais had full pwr windows.....
    Just go find a VP calais n use the motor n gear aand trims outta that.
    ________________________________________
    91 Exec
    Jan 2007
    Kingsley, Perth
    But, will there be anywhere in the BEM to put power for 2 extra doors, or will it in someway combine with my fronts? That's what im confused about.
    92 VP Calais 3.8
    May 2006
    Gold Coast
    If u really wanted to u could just tap into the power off the fronts but would be best to get all teh wireing outta the vp then u just have to run that thru to where it should go.
    Im not sure tho how hard it would be, just trying to help out a bit.
    91 Exec
    Jan 2007
    Kingsley, Perth
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Your Calais does not have a BCM... VN's never had one, none of them.
    Weird that its only front power windows, even my Berlina has power windows all round from factory.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The power window module has 1 plug in it. Should have all the wires in it!!! If not - they've been removed! - or cut somewere along the loom. I have a power window loom (both side) spare in a box - I'll have a look tomorrow to see what it should look like!
    and 3 Dangerous non ABS VN's
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    All VN Calais have four power windows from factory.
    Only berlinas and optioned SS have front only.
    You must either have a rebadged Berlina or the previous onwer removed them himself as the motors are usually only good for 10 or so years of use.
    It's not an easy job, probably not worth attempting unless you have some experience. As it's not a BCM model, you can tell if its been modified as one of the power window modules will have been removed, or will be there with no wiring running to it.
    If you need more info reply back here.
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    my calais has 4 electric windows lol and they all work good
    [SIGPIC][/SIGPIC]
  1. Electric Windows
    By moganman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 12:18 PM
  2. Electric Windows
    By crowzy in forum Electrical Wiring / Questions
    Last Post: 01-10-2008, 05:32 PM
  3. VT Electric Windows
    By crowzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 04:53 PM
  4. electric windows... hrm need some help
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2005, 03:29 PM
  5. electric windows VL
    By sparrow25 in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 08:47 PM
