Hey guys
Can anyone please tell me where to locate the fuel pressure regulator on a series 11 VN, car keeps stalling in Park and neutral so I might give the regulator a change to see if that helps.
behind the throttle body, it's bolted to the black plate that holds the throttle/kickdown cables and all that stuff. A cylindrical silver object with some hoses coming off it. Really easy to get out.
Just be sure to depressurize the fuel system before you remove it.
I'd also check the fuel filter while you're at it.
Life's Grouse in Frankston South!
I changed the fuel filter two weeks ago, I will look at regulator tonight cheers
isnt it bloted to the fuel rail??
I had a similar problem and to fix it for my VN Series 1, I cleaned out the IAC (Idle Air Control) valve. I used the Instructions found in the How To's Section and linked to here:- VN - VR: IAC (Idle Air Control) How-To Clean Thanks to Darren...
Now no more miss and no more stalling at the lights..
I hope it helps...
Well I have now cleaned my IAC and it is running much better, no stalling or low revs, BUT.... now she is reving at 1500rpm - I have turned the idle down to as low as it can go but still 1500rpms. Does anyone have an idea on how to get this idle back to 1000rpms before I have no breaks left!!!!
