Results 1 to 9 of 9
Thread: how do i take shifter out.
    cheap vn
    Feb 2006
    brizzy
    Default how do i take shifter out.
    hey just in the process of putting a b&m pro ratchet shifter in my vn and im wondering how i get the original shifter out? there is the 2 stud things holding it in.
    also how do i change from the rod style shifter to a cable style.
    has any one done this?
    any help muchly appreciated.
    thanx
    mick
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    from memory the shifters a popriveted in and you have to drill them out and make up a pannel to cover the hole..
    to change from the rod to a cabil i made up a bracket out of sheet metal. and compleatly removed the rod.
    make the bracket so it screws onto the bolts that hold the auto pan on
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VN Commodore
    Feb 2006
    cheap vn
    Feb 2006
    brizzy
    does any one have any picks.
    ive got the cabe but i just dont know how it can replace the rod bo i have to bye/make a braket to make it shift.
    thanx
    mick
    VN Commodore
    Feb 2006
    with my mates car he is going for a turbo 400 so it will be a different setup as they are already cable as far as i know.. you would have to have it spring loaded so when you go in the direction from 1st to park it would spring back. does that make sense. i can picture what i mean in my head but it is hard to explain. best bet would be to pop under and have a look for yourself..
    cheap vn
    Feb 2006
    brizzy
    yeah ive had a bit of a look under neath just not shore how i can mopunt the cable so that it works like the rod. i dont realy picture wat you were saying wat will have to spring back if i go from first to park.
    cheap vn
    Feb 2006
    brizzy
    got shifter in yesterday made up brakets and such to make work but now when i shift it only changes half a gear and i have to shift 2 times with the shifter to go one gear therefor i can only got from p to d not 321.
    some one must have put a pro rechet onto a t700. plz help.
    any comments that can help appreciated.
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    you will need to have the cabil lower on the arm coming out of the auto. this will make the shif shorter but will also make it harder to shift
    MY RIDES
    [SIGPIC][/SIGPIC]
    cheap vn
    Feb 2006
    brizzy
    is there an adaptor kit that can be bought. does your cable come in from the front of the box.
  1. shifter
    By makntracks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2009, 08:11 AM
  2. Rip shifter
    By DanoSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-04-2007, 06:37 PM
  3. vr shifter kit
    By WILD VR CLUBBY in forum Swap / Wanted to Buy / Trade
    Last Post: 08-11-2005, 11:11 AM
  4. B&M Shifter for T5
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2005, 12:48 AM
  5. B&M Shifter
    By VKCalais in forum Electrical Wiring / Questions
    Last Post: 29-06-2004, 08:30 PM
