Results 1 to 18 of 18
Thread: what is wrong?
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Default what is wrong?
    (VN S2 MOTOR)
    Ok who can tell me what is wrong with my motor.
    I turn the key on (cold start) without starting the motor and the radiator cooling fan comes on, the motor starts then stops or misfires, the engine symbol light is on, I check the code and it does one flash pause then two flashes, so that is code 12. Thats normal as in OK.
    If I take it for a drive, it starts then stops, it may drive for 20 metres to 1km.
    Any idea what could be doing this?
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    kowan's Avatar
    Sep 2005
    Far North QLD
    I tryed spitting at it and that didnt work...someone must know what is happening
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    Temperature Sensor (ECU), check that, pretty sure thats your problem. The sensor is located behind the alternator.
    kowan's Avatar
    Sep 2005
    Far North QLD
    will I need to replace the Temperature Sensor Unit ?
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    sounds like it is running in limp home mode so there must be a problem with one of your sensors, when u checked your fault codes did u let it flash for a while because sometimes it will go 12 12 12 then tell u the fault, or it could be something wrong with your ecu because i think the fault code for that is 12 aswell. just somethings to think about before u buy a temp sensor unit, there should be a way to test it, it might be in the gregorys book..
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    have you left the plug for the computer shorted for reading the fault codes?
    kowan's Avatar
    Sep 2005
    Far North QLD
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    I do not understand what you mean????
    Ok I have changed the Temp Sender Unit and it has stopped the fan comming on before the motor starts.
    So that problem has been solved.
    But it still starts and stops now and then and the yellow engine light comes on and off !!!
    What should I do now?????
    Thanks for all your help on this matter.
    vp wag
    Nov 2006
    I think he means the aldl plug which you used to show fault codes on cluster.
    kowan's Avatar
    Sep 2005
    Far North QLD
    ohh.... yeh....done that....still reads 12 doesnt matter how many times it plays 12 12 12 12 12 on and on
    kowan's Avatar
    Sep 2005
    Far North QLD
    I`m might go back to spitting at it again
    vp wag
    Nov 2006
    Have you tried disconnecting the battery for a while to reset ecu and run through test mode again.
    kowan's Avatar
    Sep 2005
    Far North QLD
    Yes it does work.
    The cooling motor fan was working when the motor wasn't on and the yellow engine light was on while the motor was running and flicking on and off and someone said to check the code to see what code was showing 12 12 12 all ok there. Someone said to replace the Temp sender unit. I changed it and the fan stop. The following day the fan started to start again while the motor was off. "BUGGAR" So I replaced the coil pack thinking it may have been that. "WRONG" That didnt fix the problem. So I changed the ECU "WOOHOO" That fixed it. Bloody old cars.
    Thanks for all your help everyone, Cheers
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    good to hear u sorted it out mate
    Matt
    - Lou Holtz
  15. #15
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    M8 i hate to say it but!... a simple reset probably would have done it rather than replace the ecu? but youv'e done it now and alls good!
    just in case no-one knows but if you pull the fuse to the fuel pump and then put it back in it will re-set the BCM (body control module) which has a lot to do with ya steering and electronics in the vehicle.
    you will know if you done it right cause both front and rear driver side indicators will flash twice!
  16. #16
    kowan's Avatar
    Sep 2005
    Far North QLD
    Quote Originally Posted by 2greedy View Post
    And where were you when I needed that info mate????
  17. #17
    VP CALAIS (SSV)
    Apr 2006
    Queensland
  18. #18
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The main engine fuse is the one to pull - leave it out for 10 sec before putting it back in.
    But the ECU can also be stuffed - one way to check is to put the old one back in before you toss it out. See if it behaves badly again.
    and 3 Dangerous non ABS VN's
  1. WTF is wrong with my CAR !!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 11:48 AM
  2. There is something seriously wrong
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2007, 01:51 PM
  3. something wrong???? HELP
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 09:46 PM
  4. Am I wrong.
    By trucker in forum Site Feedback / Site Problems
    Last Post: 20-06-2005, 04:48 PM
  5. where did I go wrong ?
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2005, 02:34 AM
