Results 1 to 22 of 22
Thread: variable power steering??
    VN Calais 5.0/vy sv8/r31 rb20
    Oct 2006
    sydney
    Default variable power steering??
    HELP UPDATED!!!!!!!hey guys got some pacemakers for my car but need to know how to tell if i have variable ratio power steer rack as they are slightly different. i think all calais have this but not sure if it has been changed to normal or not cause i havnt owned the car since new. cheers see last post
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    As far as i was aware, only VP Calais' and VQ statesmans had variable steer.
    Just hope you don't have it, i've blown 3 racks because of that crap.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VP Berlina V8 / Toyota Hiace
    Oct 2006
    SA - North
    I dont think VN's had this but if it does there should be 4 Plugs that sit between the battery and the fuse box instead of 3.
    Oct 2006
    SA - North
    Quote Originally Posted by STEALTHY View Post
    Only V8 Statesman and they were standard
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    jeez this site is full of so much mis information these days.
    Variable power steering was only ever on VP Calais and VQ2 Statesman and Caprices. V6s AND V8s. And was discontinued on VY.
    Never on the VN, and not only on V8s (thow they're all different racks) and u can tell if ur car has one as it has a solenoid sticking out of the rack.
    Oct 2006
    SA - North
    vn ss
    Oct 2005
    only on series 2 statesmans as maniac vp stated. i own a vq series 1 v8 and it does not have a variable steering rack
    VP Executive R-spec
    Jan 2005
    I'm sure they are on VP Calais too, must have been a common option if it wasn't standard?
    Oct 2006
    sydney
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by MaNiac_VP View Post
    This is what i was getting at.
    All i know is my VP has it, and its crap.
    cheers sexy
    VPII Calais
    Oct 2003
    the key to keeping it from frying is to make sure you keep the power steering fluid clean and flush it every other year as when it gets dirty, it overheats causing the soleniod to sieze in place from heat or from catching pieces of gaskets which makes the rack break up internally and then its all over.
    Oct 2006
    sydney
    ok back again, problem. the rack itself has variable ration writen on it (stamped) though i cannot see any solenoid or anythin like it on or around the rack????? help please!!!! i need to find out so i know which extractors i need
    STEALTHY™'s Avatar
    Jan 2005
    It is possible to run a variable steer rack without the variable steer working
    I cant really answer the question, but i don't see why anyone would actually put that rack in their car if it shouldn't have it.
    cheers sexy
    Oct 2006
    sydney
  15. #15
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    My variable racks just went on friday 290 for reco
    ________________________________________
  16. #16
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The variable ratio on the VN just meant that it was different in the centre than the ends. 17.2:1 on centre to 11.8:1 on lock. Variable ratio on the Stato was a solenoid that controlled the fluid volume going through the rack. The faster you went the less volume and the heavier the steering was.
  17. #17
    Oct 2006
    sydney
    Quote Originally Posted by Not_An_Abba_Fan View Post
    so wat you think?? do i need the calais/stato extractors or just the normal commodore one's
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just go the normal ones, as said above the VN never had the speed sensitive variable ratio.
  19. #19
    Oct 2006
    sydney
  20. #20
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
  21. #21
    Oct 2006
    sydney
    ok i have fitted the pacies and all is good, so for those who are interested the normal pacemakers to suit vn 5l auto will be fine aslong as you dont have the solenoid rack thingy. thanks for your help
  22. #22
    VP ute
    Mar 2006
    I had a lend of the factory manuals (all) for the VP and it was fitted as manic vp said to V6 and V8 of the up spec models.
    I never knew these racks existed and found it very interesting seeing how they were put together and the wiring involved. So I did pay a lot of attention to where one might find such a rack on a wrecked VP Calais or VQ Stato series II.
  1. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  2. Power steering Vs. manual steering?
    By cruzncommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2007, 07:45 AM
  3. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  4. Variable effort or variable ratio?
    By Timo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2007, 07:44 PM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
