Results 1 to 10 of 10
Thread: Central Locking
    MarzVP's Avatar
    MarzVP is offline I now own a TARAGO!!!
    1992 Tarago
    Aug 2005
    Port Bouvard, WA
    Default Central Locking
    Okay there is something wrong with my central locking. I push the button and the car locks then a second or two later it unlocks itself. I have just replaced the battery in the button unit but it still does it. Any suggestions?
    Cheers Marz.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Bad connection to the Body Control Module (or faulty BCM)
    and 3 Dangerous non ABS VN's
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    no b.c.m in executive model i was told, try cleaning the microswitches and connections behind the door skins on the two front doors maybe. When I was swapping my door handles over, i could make the locks do that by flicking the microswitches.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I had this problem too and it turned out to be a wire in the loom... Someone accidentally drilled through the wiring loom :
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Mine does that from time to time. Mine's to do with the tailgate lock not lining up completely so it knocks it all out of whack. A couple more presses solves the problem though.
    Life's Grouse in Frankston South!
    MarzVP's Avatar
    1992 Tarago
    Aug 2005
    Port Bouvard, WA
    Something is wrong with my door lock as when i push the button it stays up hence why the others come up. Going to take the skin off this aftrenoon and have a look and see if i can giggle something to get it to work. Thanks for the replies guys.
    fazz1977's Avatar
    Aug 2005
    Jammed actuator. One of my rears did it, then died, so I replaced it.
    vp exec
    Dec 2006
    vaucluse, sydney
    this has happened to me a couple of times, then i comes good by itself. i suspect that there is a switch in the drivers door lock mechanism that if it is not closed when u try to lock it, senses that the door is not closed then autoamtically unlocks it.
    i bolded "drivers" door because (i think) that i can lock all other doors when they are open, but i cant do it with the drivers door open. i think it is to make it harder for you to lock your car keys in the vehicle.
    I had a quick look at the schematic wiring diagram for the car. The drivers door lock switch (which i guess is in the lock mech somewhere, not the "snipper" button on the top of the door trim) is different to the passengers side door lock switch. pete.
    VE HSV GTS , VZ UTE, VL GROUP A
    Feb 2007
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by MarzVP View Post
    Same with my door, Locked all doors but the drivers and they came back up. Replaced the drivers central locking motor and all has been good since. Should be $20-$30 and some sore fingers
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. central locking?
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 10:49 PM
  3. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
  4. Central Locking
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 02:18 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
