Hi All.
A Problem that you might be able to help me with. Thanks in advance.
I have what sounds like a clutch bearing grind in compressor.
I had this renewed along with the drive belt.
however the noice is still there. so took it back to the un-named air con place.
He strobed around found no other noice in. Tensioner. Water Pump. H/balencer. Pump. (ect ) And then filled pump with 125ml of lube.
But the noice is still there. Not from blower motor either. has anyone got any
Idea at all Plz.
Thanks, superbulldog2
