i heard of those transmission coolers for autos and wanted to know are they any good and do they work
ive heard good things expecially if you tow. cooler fluid is always going to be a good thing
The genuine GM tranmission cooler uses the same as B&M core. It aids mantain shifting quality as if the tranny is cold and it would prolong the life of the box. I have fitted a genuine tranmissoin cooler and it's bolt on modificaton and it's worth every single cent.
Davies Craig make a vehicle specific one for VN-VS, which is about the best quality one you're going to buy...
Retail is $286, I've got them at $215
VN-VS Cooler
Out of curiousity does anybody know what the genuine cooler is worth? I pressume its probably a Davies Craig anyway...
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Keeping the transmission fluid out of the radiator is a good thing. Temperatures in both the trans and the cooling system fluctuate so having individual cooling devices will only prolong the life of both.
The kindest thing for any trans is to fit an aftermarket cooler. Also helps to slip trans into neutral at lights on hot day as it stops the fluid flow while sitting still with now airflow thru radiator.
