howdy how easy is it to fit a vr gearbox to a vp engine what do you do to the wiring looms is it just the gear box wiring you plug in to the ecu or what do you actually have to do to put a vr gearbox on a vp engine could you please supply any wiring diagrams and give me any advice. also can i later put a vr engine to a vr gearbox if the vp engine goes on me oneday after putting a vr gearbox in to a vp.
ive started a similar thread in the same forum, from what i understand it will all bolt up its just some loom/computer mucking around as the vr box is controlled electronically when to shift, i reckon it might be a simpler swap if you did the motor and box at the same time and bought a doner car u can just tear anything off
