Results 1 to 6 of 6
Thread: VN 5 litre Engine cut outs
    Sep 2004
    Default VN 5 litre Engine cut outs
    Gday all!
    I own an 89 VN ex interceptor 5litre 5 speed. I have been having serious issues with it cutting out. If its under heavy labour then it just dies untill u let you foot of the pedal and then it goes again. If you leave your foot on the gas it throws an error code but it clears almost straight after. I really wanna get this sorted out with out spending a fortune cos i wanna sell it.
    Anyone ever had same problem?
    car
    Jul 2006
    greensy, melb
    have u checked ure fuel pump???
    "A life lived in fear is a life half lived"
    Sep 2004
    Yeah i have replaced the one in the tank but there is a regulator i need to look at at the back near the manifold i think. Did some tests blocking the vacuum on it and block it did nothing????
    VP Wagon V8 93
    Nov 2006
    Im not an expert but perhaps change or check the oil sender as this helps send power to the fuel pump
    VP Wagon V8 93
    Nov 2006
    Also Im not sure if this model has a Ignitian module bolteded to the passanger side of the car or not but if it is faulty it might start to die slowely hence your cutting out, Test your spark, start form leads go to coil then down to ignitian module then to oil sender etc etc.
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
    even the coil can be on its way out as i had the same prob, it used to go pretty much fine when just cruising around but as soon as i give the throttle stick it would die on me
    THERE IS NO REPLACEMENT FOR DISPLACEMENT
  1. WTB: 5 Litre engine covers!
    By Blown V6 Hatch in forum Swap / Wanted to Buy / Trade
    Last Post: 24-12-2007, 05:32 PM
  2. Holden V8 Heads & engine & parts. 308/253 5 Litre
    By DumpedVT in forum Parts And Other Items For Sale
    Last Post: 11-12-2007, 07:27 AM
  3. Stauling engine- VS 5 litre ute
    By bradyboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2007, 01:07 AM
  4. vt v6 computer pin outs
    By hinterland in forum Electrical Wiring / Questions
    Last Post: 27-12-2005, 10:04 PM
  5. Speeding outs?
    By Shortsta in forum General
    Last Post: 01-12-2005, 06:42 PM
