Results 1 to 5 of 5
Thread: Engine missing at revs
    NVS 90 is offline 140rwkw N/A V6
    VN Belina (1990)
    Oct 2006
    Default Engine missing at revs
    hey all. just wondering if anyone could help me.
    i have a VN series 1. when i get up it it starts to break down. it gets to about 3000rpm and doesnt rev smoothly.
    ill be checking the crank angle sensor today, but i have replaced the coil pack and the DFI module looks good.
    any idea why it breaks down.
    thanks all
    VN Commodore
    Feb 2006
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by defa View Post
    sounds like leads to me
    I second that - under load like going up hills - first place to look is leads
    and 3 Dangerous non ABS VN's
    Commodore VN 3.8 / VP 3.8
    Apr 2006
    Auckland West
    Hey man
    I had the same problem after I changed my CAS, what it was is the CAS is adjustable and that can alter the timing. I adjusted the little white unit on the CAS one click and it made my car run mint
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    An hairline crack in a spark plug can also cause the symptom you describe.
  1. Engine revs changing up/down when coasting over 80km/h
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 09:18 PM
  2. VT v6 5spd engine holding revs when i clutch it
    By xx1600xx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2008, 09:02 AM
  3. Missing badly when idleing with high revs
    By aussielyn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-04-2007, 01:46 PM
  4. Engine vibration at low revs
    By Mungus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2006, 07:53 AM
  5. engine missing
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:07 PM
