Results 1 to 4 of 4
Thread: Power Steering Pump Hose
    VP Commodore
    Nov 2006
    Default Power Steering Pump Hose
    I need to replace a Powersteering pump hose on a VP commodore i assume it is the low presure hose as it has hose clamps toh old it on and ios the thin one of the two. only its bent to a special shape which will be hard to obtain..
    can i use just a normal straight length? and if so what sort of hose is it?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    gday u can use any sort of pressure hose and buy like 75 cms to cover your arse, its cheap as. my line doesnt have a bend in it and its set up the same
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Quote Originally Posted by Meerkat View Post
    M8 if it's the low pressure hose i suggest you be very careful! i just had to redo mine and it is real bastard to get at! i nearly snapped mine so be very careful, if your replacing the whole line it wont be so bad but if your just replacing the rubber hose be careful!
    gasman is offline GASMAN
    VP EXECUTIVE S1 V6
    Feb 2007
    PENRITH
    Default pwr steering
    its only that shape cause its gone hard just replaced min only 10 buks but also change the clamps ok. 1 otherthing dnt brake the ###in plastic bit on the resivoir cut it with rasor blade and be vry carfull not to break it and do it when engine is cold
  1. hose of transmission or power steering
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2007, 11:52 PM
  2. Pressure Hose on Power Steering...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2006, 11:02 AM
  3. VK V8 power steering pump
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-06-2006, 09:00 PM
  4. Power Steering Hose
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2006, 03:02 AM
  5. Changing power steering hose.
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2005, 02:39 PM
