Results 1 to 24 of 24
Thread: rebuild rack and pinion DIY?
    VS Calais
    Apr 2005
    Default rebuild rack and pinion DIY?
    hey guys
    just wondering if its possible to rebuild a vn rack and pinion? i got told that it needs special tools, but that was from a rather unreliable source.
    i think most of the movement in mine is in the joint in the rubber cover thingo on the drivers side. can this be replaced without rebuilding the whole thing?
    thanks
    VN Commodore
    Feb 2006
    i wondered the same thing and am going to pull one apart one day and see if ya can or not..
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    you can do it, just need an instruction manual and some basic tools and a feeler gauge.
    i overhauled one at trade school last week and its pretty easy if the pinion isnt damaged.
    parts would probably cost the earth tho being genuine and all
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    you DONT need an instruction manual, you DONT need special tools, you DONT need anything. just rip the rack off and if the pinion and whatnot are all good, you just need to replace the seals and whatnot, then bingo.
    Boonz's Avatar
    Jul 2005
    and what about the shims for the yoke???? what about the torque specs for the pinion preload??? you need some form of a guide you know....you can wreck bearings and seals when you dont use the correct torque settings,
    VP 5spd
    Nov 2006
    QLD
    Quote Originally Posted by Peanuts Inc. View Post
    i just took mine out pulled it to bits (cuz it was leaking like a fords fueltank) replaced everything, put it back in and bingo, didnt even need to think.
    Boonz's Avatar
    Jul 2005
    im just saying to do it properly you need to use these tools and guides....but his has movement so it needs to be overhauled or just have the ball joints replaced
    VS Calais
    Apr 2005
    Thanks for the replys guys
    peanuts: do you have a copy of these instructions? you think i can get the parts at say repco or sprints etc?
    The reason i want to pull it to bits it because theres movement in it. It leaks something rotten, but ive stopped caring as of a few months ago
    ive got access to most common tools, drills/bearing press all that stuff, are there any job specific tools needed? can said tools be made with a welder etc?
    thanks again
    edit:
    oh and i had a look at an old vl (i think) rack i had around, and noticed its got little pins that i assume hold the ball joints on the main shaft. I tried to drill them out, but i think they were harder than the shaft, so the bit kept slipping off. Is the vn the same? if so how do you get them out? cheers
    Boonz's Avatar
    Jul 2005
    spanners, pin punches, hammer, and a bigish multigrips for the inner ball joints...nah i dont ahve a copy of them. try a gregories manual or something and i think most parts should be available at repco
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    VS Calais
    Apr 2005
    I conviently have a gregory's manual on my desk atm
    Doesnt tell you how to do dismantle the power steering rack, but does tell you how to do the manual steering rack. I guess the process may be pretty similar, but they did use some weird lookin tools.
    However it looks like the tie rod/ball joint simply unscrew from the main shaft, so i should be ok to replace them.
    cheers guys
    Nov 2005
    The Rack ends are really the only diffrence between the ps or conventional steering.Rack ends are about $60 a pr from memory.
    Tony 308vkcalais:
    VS Calais
    Apr 2005
    where abouts you get the rack ends from?
    surely theres some significant differences in the main unit for power/non power... what about the valves and stuff (i guess theres gotta be something like that for the power steering...)??? what are the parts worth to reco the seals and the like?
    cheers
    VP SS V8 and Toyota Landcruiser
    Aug 2007
    Brunei
    Hey guys,
    I am in the process of doing the job and I would like to have a little advise.
    How do I get the rack out of the housing?
    I think you have to open up the side with the arrow, but not to sure how to do that.
    I allready wrecked a bearing so I want to be careful.
    Do you unscrew the end cap (with 4 holes) or do you need to do something else?
    Thanks
  15. #15
    VN-V6/2005 SV6
    Jul 2005
    Quote Originally Posted by cit51 View Post
    Hey guys,
    Thanks
    man you really need a gregory's manual ...i did one about 12 months ago.. got a seal kit from local auto transmision place like $50 bucks or something..you need a torque wrench for this for sure..and that end cap does need to come out...thats were you will need to make a tool to get in to those holes
  16. #16
    Aug 2007
    Brunei
    I do have this seal kit from powersteering australia, costed me 35 AUD.
    And yes I probably have to get me a gregory manual, to keep me from damaging any more
    Does this endcap screw out?
    VN-V6/2005 SV6
    Jul 2005
    yes it does come out
  18. #18
    Aug 2007
    Brunei
    Well, I did make a special tool, thanks to my garage.
    If people are interested I can post up a little manual how to do (and not to do) this job.
  19. #19
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    nice tool man should sell it on ebay just dont put up a pic of it someone will buy it lol good to see you got it done by yourself
  20. #20
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
  21. #21
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    heres a exploded view of the various parts of the power rack looking at factory book that tool above to unscrew retaining nut is the only specialised tool needed to do job....there are some torque specifications and special holding tools but nothing that you cant improvise if you have a basic and patient understanding of how it all goes together.
    Attached Thumbnails Attached Thumbnails rebuild rack and pinion DIY?-steering1.jpg
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  22. #22
    Aug 2007
    Brunei
    Ha, now that is a file I actually liked to have before I started the job hehe.
    The only thing I can see I forgot is the little o ring at the top of the pinion.
    I did not take the pinion apart.
    Hopefully this is not neccesay, because I am just finished putting everything back together and am too lazy to open it up again.
  23. #23
    Aug 2007
    Brunei
    Just finished putting the rack back under the car.
    Fired up the engine and checked all the connections.
    Seems nothing is leaking, at least from the steering rack.
    The engine and gearbox are leaking so I have to replace those gaskets, that will be the next project. Alltough I think I let the garage do that messy job.
  24. #24
    VX 'S' S1
    Apr 2005
    South East,Victoria
    are these racks the same as the VX power steering ones , mines got a leak too
  1. rack and pinion
    By hN! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2012, 06:14 PM
  2. Help!!!!! Pinion Seal
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2008, 01:17 AM
  3. Rack and pinion
    By wondering in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2007, 11:14 PM
  4. Pinion oil seal
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2006, 01:11 PM
  5. VN Rack and Pinion Problems
    By lealea in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2005, 07:38 PM
