Results 1 to 10 of 10
Thread: Home made strut brace
    VS Calais
    Apr 2005
    Default Home made strut brace
    hey guys
    Just wondering if anyone here has made a strut top brace for a commodore?
    I was looking at buying one, but i cant justify that a piece of pipe and a couple mounts is worth $200...
    if you have please post pics
    thanks
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    it depends on where u work and what kind of steel u can get access to, i brought a whiteline strut brace and think it was money well spent, i could of made one myself but it would be to much screwing around and the whiteline ones r well made, work well and look good, i hate driving a vp without one
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    VS Calais
    Apr 2005
    1. im cheap
    2. i dont care what my engine bay looks like. so long as the car drives better ill be happy
    3. did i mention im cheap? haha
    At the moment im thinkin a nice piece of 1" OD galvanized pipe and some fat pieces of angle iron should do fine. geeze i sound like a bogan
    cheers
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A strut brace on a rear wheel drive makes hardly any difference IMO, you're probably better off replacing all your bushes with nolathane ones, putting in some decent shocks and keeping your wheels aligned by a good wheel aligner.
    VS Calais
    Apr 2005
    Yeah im acctually thinking that its probably not worth it
    Went down to the local pedders, and the guy said that he wouldnt bother putting one on a vn performance wise, unless youve gone the koni/bilstien path. The guy said that vts etc are far worse for flex than vns.. surprising to me.
    Ive already got nolathance, pedders fe2 height springs, gt gas shocks, whiteline adjusable front bar, adjustable tops. im just looking for cheap ways of tightening things up a bit.
    cheers guys
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    VN Commodore
    Feb 2006
    vn's still move a lot in the strut towers. i am going to put one on my car when i have the money..
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VP Executive R-spec
    Jan 2005
    It's on my list of things to buy too just so it stops the car bending and twisting on every bump really, that's bad for my car and will make it break in half one day :|
    VP Exec
    Jun 2005
    I've yet to see a good ie. effective strut bar for a Commodore. The ones with spherical bearings, while easy to mount and unlikely to cause overstressing (and cracking) elsewhere in the body, are flexible precisely where they should be stiff.
    I have seen a couple of good designs on R33 and R34 Skylines and I'll try and dig up a few pictures.
    Good strut braces should be designed to stop the strut towers "lozenging", particularly in front view. By that I mean if you draw an imaginary box, in 2D, from across the bottom of the car, up each strut tower and across between them, the strut bar should prevent that box from distorting. This means that the 'bar should have no flexible joints and be bolted to all three strut mounting bolts.
    The idea is to increase stiffness, not strength so an RSJ or railway track bolted across the towers is not the ideal. Large diameter (limited by what will fit) and thin wall tube is best. Straight runs of tube are best - not possible in reality. Mild steel is as good as anything because steel alloys are all of similar stiffness (but not strength). Aluminium alloy is even better.
    Picture: http://www.netcarshow.com/nismo/2005...llpaper_0c.htm
  1. VT Strut Brace
    By gonz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 07:43 PM
  2. Strut Brace
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2006, 09:05 PM
  3. home made bullbar vs
    By ringfeder3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2006, 10:04 PM
  4. Strut brace on V6 VT ?
    By grafxworld in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2006, 12:53 PM
  5. Home Made intake
    By Phantom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 06:41 PM
