Results 1 to 18 of 18
Thread: Trouble shoot for me please guys
    missmcudd's Avatar
    missmcudd is offline The Bee Sting butterfly
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    Default Trouble shoot for me please guys
    Hey guys im having a problem and im going to use the excuse that im a girl and dont know how to fix it.
    Recently my vp lx had problems with the fuel pump and the fuel pump was replaced. Everything was working great until
    all of a sudden my fuel guage stopped reading properly.
    when my car starts the fuel guage goes up to 3/4 full and then sticks there. When the car is off it goes back down to normal... its not actually stuck it still moves up and down but reads the same amount regardless of how much fuel i have in my car. So its annoying, my boyfriends cousin says its the cluster that needs to be changed but i think its not that its the thingy in the fuel tank thats stuck or bent or something when they changed the fuel pump.
    I want it fixed! and no filling my car up and resetting the meter is not an option because i dont want to have to "work out" how much petty i have. I like to know exactly how much i have!
    So what can i do?? Any thoughts on if i should just buy a new cluster and hope this fixes it or should i get someone to go and fix the meter thingy in the fuel tank?
    take it easy and if its easy ....take it home!
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    try slapping the top of the cluster, if this fixes it then its the solder on the back of the cluster, normally it sticks in the empty postion thou.
    I would say off the top of my head that you are correct & the arm for the fuel float has been damaged.
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    i would have 2 agree and say the arm has been damaged.. doesnt sound like the cluster
    Check out my ride and rate it high plz
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    sounds like the arm is sticking when it gets to that certain point...try what norti said it ususaly helps..... or it could be the sender on the fuel tank thats buggered up
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    All gauges are pretty sensitive things, all it takes is a short in the wiring and they bugger up. Have you touched any of the dash since the pump was replaced? Sometimes if a wire gets shorted that leads to your cluster then this would damage the gauge. I had a car that had gauge issues and everytime I touched the tank sender or dash I needed to disconnect the battery and I never stuffed a gauge after that.
    I tend to disagree with the float being damaged as this would have shown itself the instant the pump was changed, not a while after.
    Disconnect the sender at the tank and see what happens to your gauge, it should go straight up to full as there is no resistance from the sender to bring it down. If it doesn't move then it's probably the gauge.
    missmcudd's Avatar
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    hmmm i have smacked the top of the cluster and it just stays in the same position will only go down when the car is turned off.
    =( how much is it to get some mechanic to fix the arm thingy because the guys that changed the fuel pump said it might have been bent which is why its fkd now but they are too lazy to fix it (its my bfs cousins) so yeh i need someone to fix it
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by missmcudd View Post
    then smack it harder??? or smack your boyfriend and tell him to fix it :P
    try borrowing a cluster, those things are piss easy to swap probbly a sticky gauge as when the cars off it SHOULDNT be displaying any fuel they'res your indication of a rooted gauge not sender, new cluster = $50? and if you dont have a tacho you can get one!
    Jun 2005
    if its an lx then its a level 3 dash. are your digital readouts for fuel usage working?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    If it,s only happened since they changed the fuel pump i'd be inclined to say they have damaged the float arm or the little wires that the sender slides up and down il'l nearly bet my left .... thats what it is.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by 2greedy View Post
    If it happened straight away I would agree but it didn't so I would say it is something else like the gauge itself or a short in the dash somewhere.
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Yea ok i didn't realise that it didn't happen straight away but still it coould be worn and causing the prob?
    Probably the first thing i would do is pull the sender out of the tank and check that it's not damaged at least that way you eliminate that end of the problem therefore it can then only be a bad conection somewhere or in the instrument cluster.
    what is tending me to lean towards the tank sender is the fact that the gage is working! Now if it was a short or bad connection the gage would either go full scale or not read at all? just not showing true reading which makes me think something is wrong at the tank end?
    you would nearly have to say that the float in the tank is stuck in 1 position? try getting under the car and bash on the tank near the sender and see if it alters at all? you may be lucky and it may free it?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If the gauge was subject to a short then the resistor may have melted causing the needle to jump to its current position. This has happened to me so thats why I'm suggesting a problem with the gauge. But by all means check everything, it could very well be the sender unit. Unplug it and see what the gauge does.
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    maybe the new pump they put in the tank is jamming the guage sender in the tank holding it off the bottom or they bent something while they were in there my mates did this after he got the siphon hose tangled round his
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Look at it this way... it could be the gauge, and it could be the sender in the tank. You won't know without replacing one of them.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
  15. #15
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    dont resistors go pop ??? lol or maybe thats what happens if u cut them in half with sissors... at tafe we make LED's go bang by putting like 50A through them at like 12V
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by PaRaDoX616 View Post
    The sender and the gauge are resistors. The float moves a needle up a coil of wires and as the needle gets to the top the wire in effect becomes shorter creating less resistance. This signal measured in ohms is sent to the gauge which has its own coil of wire that measures the resistance and sends its own needle along the coil in response to the resistance it measures.
  17. #17
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    nah they just burn, cap's go pop some types do anyway.
  18. #18
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Stick your head under the car and look at where the fuel pump assembly is, there's a round plate which holds the piping ans wiring, and should have a flat edge upper most, like a circle with a flat top.
    Illegitimi Non Carborundum
  1. hey guys need lil help..
    By m0zzaVP in forum General
    Last Post: 14-10-2007, 08:53 PM
  2. Photo Shoot
    By UREZY in forum General
    Last Post: 25-09-2006, 12:08 AM
  3. What do you guys think of this
    By coolvxss in forum The Pub
    Last Post: 29-07-2006, 10:37 AM
  4. Hey guys just saying hello
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 11:32 AM
  5. AU Ford Wagon (don't shoot me)
    By Just_Ice in forum Parts And Other Items For Sale
    Last Post: 07-02-2006, 11:16 AM
