Results 1 to 11 of 11
Thread: VP to VS interior
    Feb 2007
    Default VP to VS interior
    Hey there, i know this has maybe been covered many times but i couldnt find anything in search.
    Will the VS (berlina) interior or any other type bolt into a vp?
    including rear seats....
    thanks,fadz.
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    yes, it should you can fit the VT interior in so yeh id say you easily cud.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    rear seat i think will be ok into a vp, everything else should be fine, but, door trims will only fit properly with the vs dash fitted.
    otherwise, front seats and everything else should bolt in no probs. (ive got vs seats in the vn)
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Yeah all seats, vn-vs are the same, they are interchangable, as for the door trims, i dont think the front trims will fit from vr/vs into vn/vp without modding, cause of the air vents n whatnot
    hakhawk's Avatar
    Jan 2005
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    how easy it it to put a vr/vs dash into a vn? ive got vs door trims, is it worth it coz the vr/vs dash looks so much better than the vn's one
    VN Commodore
    Feb 2006
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Nah its deffinaely worth it, check out SC's how too... it sums it up best. Its some work but worth it. You have to make some adjustments to air vents to get full use. Mainly fornt window demister. Otherise it aint that ahrd.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    goose2's Avatar
    goose2 is offline 40. the new 20
    VT BerlinaWagon/VZ exec wagon
    Sep 2004
    Ballarat, VIC.
    the dash ouda the vr/vs wont go into the vn/vp properly .the heater box is different and the demister vent tunnel [welded to fire wall] is different to vn/p as well .if you don't want dash vents and heater and it's just for show it go's in
    If i wanted to break ya balls i woulda kicked ya girlfriends handbag
    VP ute
    Mar 2006
    yeah you can't demist the windscreen with the VS dash unless you change the fire wall.
    The lower half of the dash is much the same, the cetre consol is the same and the seats all bolt up fine
    May 2005
    .....SE Burbs
    Quote Originally Posted by Fu Manchu View Post
    no, you just have to make an adapter vent... not that hard...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  1. Interior kits or changing Interior
    By iRiot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2011, 08:54 AM
  2. Replies: 7
    Last Post: 27-02-2007, 03:55 PM
  3. Interior
    By wes_v8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2006, 08:24 PM
  4. vn-vs interior
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 11-10-2005, 07:19 PM
  5. vh sle interior
    By 308commodore in forum Parts And Other Items For Sale
    Last Post: 24-08-2005, 02:41 PM
