Results 1 to 7 of 7
Thread: Auto Trans Leak
    93 Lexcen
    Feb 2007
    Default Auto Trans Leak
    Our 93 V6 Lexcen has developed a bad leak from the bellhousing area. I removed the trans, installed new front & rear seals, filter and pan gasket. Didn't positively identify the cause of the leak while the trans was out. Put everything back together and the leak is still there. Does anyone have a suggestion to what may be the cause of this leak. It is definitely trans fluid. The rear main was dry as a bone. Could it be a hairline crack in the converter? Or a crack in the front seal carrier?
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    93 Lexcen
    Feb 2007
    90VNWAG0N, I checked out some similar threads and maybe the pump needs re-bushing. Have not got my box out as yet so don't know exactly how this leads to an oil leak but I will follow it up. Whatever it is still means removing the trans
    Again
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    Check the power steering rack, because that uses the same oil as the auto trans.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check to see if any fluid is on your power steering lines as this tends to leak and run down appearing as though your tranny is leaking.
    VC Twin Turbo, VN Turbo, VY Storm
    Oct 2006
    Quote Originally Posted by donnowhy View Post
    Again
    Yes this is very common if the seal is hard and the rubber part cracks into little bits then the seal can be the problem if its still soft its the bush which means pump out and then rebuild it with new bush and seals etc. sloe will need to have the converter neck checked for run out.
    93 Lexcen
    Feb 2007
    Thanx Furious_8. I have renewed the seal so I reckon it must be the pump. Is this job a proposition for a competent mechanic (me)? Or should I take it to a specialist? Are the pump parts hard to source?
  1. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  2. Another Auto Trans Leak
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2007, 07:48 PM
  3. auto trans leak!
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2007, 11:45 AM
  4. auto trans oil leak
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2006, 07:00 PM
  5. auto trans fluid leak
    By jenzee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2006, 06:12 PM
